Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > STAR PLUS on CS5000
Author Thread: STAR PLUS on CS5000
Username: Nbpanjwa
Can any one help how to get STAR PLUS on CS5000.
I tried PID Scan with 12443H TP and V5666, A5667, P5666, NO LUCK
OR to add in Channel Master
Thanks
Username: Tejneil
Post Number: 21
Same here, no luck with CS5000, followed the same instructions several times with no success. Nalin, Please help!!!
Username: Nydas
Post Number: 8496
I have friends with a CS 4000 or 5000. We could not do anything till the new BINs got released. I can't get in touch with them till this evening. I will post success or failure as soon as I can.
Username: Tejneil
Post Number: 22
Thanks a bunch, Nalin
Username: Nbpanjwa
Can someone please help me srtup Star Plus on C00lsat 5000????
Username: Nycman77
Post Number: 13
can anyone tell me y chann3l 588 and 605 dn coolst5k isnt workin there my tooo fav intl ones
Username: Kirankumar
Kenya
Post Number: 1764
This Will Work
MENU---> Channel List---> Channel List Manager----> Edit Channel---> and then press yellow botton ( Add Channel) and then
Change channel name
Frequency------ 12443
Video PID------ 5666
Audio PID------ 5667
PCR PID-------- 5666
and then press yes now you r good to go for Star Plus :-)
i got mine on channel 7222 but could be any channel
enjoy
Username: Nycman77
Post Number: 14
hey african u have an answer for me perhaps on my above question?
Kenya
Post Number: 1765
I have a feeling 605 might be assigned to starplus
very soon,as far as 588 i don't know,but i suggest you do blind scan.i am not at home right now,but i can check for you in the morning
Username: Nycman77
Post Number: 15
ok i would appreciate it african thank you
Username: Jppatelahd
Post Number: 73
african do u know it is possible on captive works 600 premium?
i am asking this questions too many times but nobody comes to help?
Post Number: 74
Kenya
Post Number: 1767
yes on all receivers with 61.5
Username: Leo_here
Post Number: 61
I dont think anyone is getting this channel on CS5K
It worked fine on my VS and PS
On my CS,I tried everything but all I am getting is a blank channel with no audio or video
ANybody knows how to make it work on CS5K ??
Kenya
Post Number: 1770
Leo i got it on my cs5000
Username: Leo_here
Post Number: 62
What did you do African?
I am getting 2 605 channels..first one is greek and second one is coming up as blank !
Kenya
Post Number: 1777
dont try to get it on 605
like i got it on 1772,it shows martha stewart but star comes on.follow what i have posted and let me know
Username: Krishn
Post Number: 87
African:
I was trying to help a friend who has CS5000, however Chanel List manager could not be found at all in the Menu. His menu is as follows
Menu---> Channels---> Set Favorite | Edit Channels |Move Channels | Lock Channels | Skip Channels | Delete Channels
How did you get the choices you posted -
"MENU---> Channel List---> Channel List Manager----> Edit Channel---> and then press yellow button ( Add Channel) and then ...."
Is it because you have loaded some channel manager that extends the menu?
Also tried PID scan for another channel, it first deleted other satellites then deleted all channels. Is it a problem with CS5000?
Kenya
Post Number: 1780
menu>channels>edit channels. then press yellow button
Username: Krishn
Post Number: 88
Anyone has info on Channel List---> Channel List Manager on CS5000, please see the post above and provide your input
Username: Krishn
Post Number: 89
Ok thanks sorry - concurrent posting
Username: Krishn
Post Number: 90
African - menu>channels>edit channels. then press yellow button
This sorts the channels as per the transponder, looked at system info it says Boot version: 2.1 and ch version: 007, may be need a different channel version can you check yours and post
Kenya
Post Number: 1782
then scroll to 12443 and press ok
Username: Nbpanjwa
African,
Subash is right, I too don't see Channel List Manager. When I do menu>channels>edit channels then press yellow button, I get option to add TP and when I add 12443 then H, I get a message: "TP already exist".
I think we may not be using same factory bin as you. If so please send us a link to the factory bin that you are using. We will flash that first and then new bin 168, hopefully then we may see Channel list Manager to add NEW Channel.
Kenya
Post Number: 1784
got factory bin from ftabins
Username: Nbpanjwa
African, I got it from the same place too then how come I don't get the same options to add channel as you do???? I have posted the same quiestion on several other sites. No Luck yet... Something is missing somewhere and I'm sure someone out there knows how to fix it... Hope help will be coming soon...
Username: Krishn
Post Number: 91
nb - the only way you can add is from
Menu---> Installation ---> PID scan
However be careful, first save the Channels from the loader, since you may loose all channels if you do PID scan. I was helping a friend and noticed CS is not stable.
nb what is your boot version and ch version from system info?
African could you please post the Boot Version and
Ch version from system info?
Username: Nbpanjwa
Post Number: 7
PID scan did not work for me, I lost all existing channels on that TP and got few others but not Star Plus. Subash, can you explain how you were able to get Star Plus by doing PID scan.
Boot Version: 2.10 (09:14) and CH Version: E007
African, Subash what info you got???
Username: Krishn
Post Number: 92
nb system info mentioned by my friend is:
CH Version: E007
same as yours
make sure you enter all fields in PID:
however as african has said channel name may not come up
Username: Nbpanjwa
Post Number: 8
Subash, as I said earlier that did not work for me.
Wonder, why no one else is helping for C00lsat 5000??? I guess, people might have trashed it by now...
Username: Nydas
Post Number: 8633
Then enter all the values. It worked to get Star Plus on a friend's CS4000 using the latest BIN.
Username: Nbpanjwa
Post Number: 9
Nalin, that did not work for me on CS5000. Anyone other sugesstion???
Username: Jay228
Windsor, Ontario
Post Number: 22
There is no data for Star plus in EPG.
Username: Nbpanjwa
Post Number: 10
Finally.... I got it.
I did
-->Factory Reset
-->Bilnd scan TP 12443
Got 6 channels but on TP 12445
-->Channel edit on Channel 7772 and entered 5666, 5667 & 5666 respectively where it belongs.
-->OK
Bingo! STAR PLUS appeared!!!!!
Don't give up folks......
Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > STAR PLUS on CS5000 [ « Previous ] [ Next » ]
