Thread: Star India Plus WORKING ON ALL RECIEVERS |
Bronze Member Username: Taran420
Post Number: 52 Registered: Jan-07
| Posted on Saturday, February 23, 2008 - 01:44 pm: |
Ok guys i can confirm STAR INDIA PLUS on Echo 3 61.5, on co*lsat, viewsat annd sonicview to get it, you got to manually add the information The info you got to edit is the TP Video, Audio and Pid numbers For Viewsats you go to Menu, Channel scan, not go to Tp 12443, and then at the bottom select the color that says "ADD USER CHANNEL", when you do that a box appears, where you can enter the info below. Then do the TP scan and the channel will be named "USER CHANNEL" you can do the same for any reciever, all you need to do is edit the TP info, and this can be done in any boxes heres the info you need to enter Coutesy Dizasta Echostar 3 12443 TP V5666 A5667 P5666 I know their are a couple of threads, but hopefully this will make it clear |
Bronze Member Username: Sam_patel
Post Number: 78 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 02:17 pm: |
can u tell me how to get star plus on c00lsat plzzz can u give me the info for how to set with c00lsat7000 thanks |
Silver Member Username: The_devil
Post Number: 134 Registered: Aug-07
| Posted on Saturday, February 23, 2008 - 02:23 pm: |
can u tell me how to get it on captiveworks 600p |
Silver Member Username: Xtrawest
Post Number: 160 Registered: Nov-05
| Posted on Saturday, February 23, 2008 - 02:28 pm: |
Is it available on 148 as well??? |
Gold Member Username: Nydas
Post Number: 8427 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 02:40 pm: |
ON PANSAT 2700, PANSAT 2700 CLONES AND PANSAT 2500/flu CONVERTED. Menu/Dish Setup/Advanced scan Select Echo 3 at 61.5 In TP menu, right arrow till 12443 H Down arrow to Video. Change Auto to 5666 Down arrow to Audio. Change Auto to 5667 Down arrow to PCR PID. Change Auto to 5666
Post Number: 79 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 03:18 pm: |
hii Nalin Nyda i was try ur instrution on my c00lsat7000 and i did scan but no luck there is no chennel can u tell me the how can i setup with c00lsat7000 plzzzz thanks |
Bronze Member Username: Khopdi
Post Number: 94 Registered: Apr-07
| Posted on Saturday, February 23, 2008 - 03:20 pm: |
On my 3500SD, how do I change change from auto to 5666 (5667 & 5666)? |
Bronze Member Username: Jaz06
Post Number: 64 Registered: Nov-06
| Posted on Saturday, February 23, 2008 - 03:23 pm: |
I tried it the way taran said it. I have to channel 605 but they are both greek or something. I changed the numbers. I have a viewsat ultra. |
Bronze Member Username: Sindhiguy
Post Number: 23 Registered: Dec-07
| Posted on Saturday, February 23, 2008 - 03:24 pm: |
Star Plus Working Good For Me Thx A Million |
Post Number: 53 Registered: Jan-07
| Posted on Saturday, February 23, 2008 - 03:37 pm: |
jaz, its not channel 605, i had it all the way at the end and it said "user channel" |
Bronze Member Username: Shamhd
Post Number: 24 Registered: Oct-07
| Posted on Saturday, February 23, 2008 - 03:49 pm: |
hey NALIN or TARAN how do i get it on 148 plz |
Silver Member Username: Vndpatel
Post Number: 549 Registered: Mar-06
| Posted on Saturday, February 23, 2008 - 04:01 pm: |
how do you do it on the nfusion?? |
Post Number: 65 Registered: Nov-06
| Posted on Saturday, February 23, 2008 - 04:12 pm: |
I found the channel listed as user channel it says echo 3, 12443 2000 H 3/4 but it is still black. What am I doing wrong. I changed the other numbers too. plzzz help |
Bronze Member Username: Vic123
Toronto Canada
Post Number: 92 Registered: Jul-06
| Posted on Saturday, February 23, 2008 - 04:15 pm: |
thanks a billion guys star plus works amazing post guys keep up the good work mates Cheers  |
Toronto Canada
Post Number: 93 Registered: Jul-06
| Posted on Saturday, February 23, 2008 - 04:16 pm: |
sham its not gonna work on 148 only 61.5 read mate |
Silver Member Username: Vsp
Post Number: 238 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 04:17 pm: |
Cheers vic and thanks a lot everybody |
Post Number: 551 Registered: Mar-06
| Posted on Saturday, February 23, 2008 - 04:50 pm: |
anyone know how to get it on nfusion? |
Silver Member Username: Plymouth
Quebec city,
Quebec
Post Number: 231 Registered: Jan-08
| Posted on Saturday, February 23, 2008 - 05:30 pm: |
Vndpatel you get with ip adress  Joke |
Post Number: 8436 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 06:01 pm: |
What about CW receivers? |
Post Number: 8437 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 06:14 pm: |
Plymouth: Which looks better with you name attached to it in the headings? Star India Plus WORKING ON ALL RECIEVERS (postive) Star Plus Will be no longer available... (negative) That's wahat I mean by posting in positive thread. if King wants to find out more direct him to the positive threads |
Bronze Member Username: Reach_honey
Post Number: 87 Registered: Mar-05
| Posted on Saturday, February 23, 2008 - 06:58 pm: |
Ok I have never used 61.5 for any of my channels. I'm getting all South Asian Channels and all American/PPV and everything. So how do I get adjust my 61.5 angle. What do I enter in Antenna Setup Below are my current setup echostar 1,2 148 OCS-DP LnbFreq 11250 TP Fre 12224 Disq Port 4 echo start 7 119 OCS-DP LnbFreq 11250 TP Fre 12239 Disq Port 1 echostar 8,10 110 OCS-DP LnbFreq 11250 TP Fre 12224 Disq Port 2 |
Quebec city,
Quebec
Post Number: 238 Registered: Jan-08
| Posted on Saturday, February 23, 2008 - 07:15 pm: |
Ok nalin Now i understand Thanks for this reply Good tv |
Silver Member Username: One_eye_jack
Post Number: 426 Registered: Nov-07
| Posted on Saturday, February 23, 2008 - 07:43 pm: |
http://www.lyng*sat.com/packages/dish61.html Ant 1 Satellite Nagravision 2 605 5666 5667 Gr Channel 605 http://ekb.dbstalk.com/dishlist.htm Antenna Satellite (Greek) ANTEN 605 12 61.5° Some one here should let Lyngsat and Dish Network know that they posted the wrong info. on their sites. On the other hand maybe someone is playing with your minds. Or well like they say it will come out in the wash. BTW I have almost forgot to say maybe Dish Network stole this Star Plus Channel from DirecTV |
Post Number: 8441 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 07:55 pm: |
Probably DTV had an exclusive contract with Star Plus and this contract might be expiring or just expired. There will not be any stopping DN offering it. |
Post Number: 54 Registered: Jan-07
| Posted on Saturday, February 23, 2008 - 08:04 pm: |
well right now this channel is TRUE FTA on Dish. And the next question is, are all the STAR channels gonna come on dish.........i hope so |
New member Username: Rekha
Post Number: 3 Registered: Oct-07
| Posted on Saturday, February 23, 2008 - 08:28 pm: |
Nalin: Good work. Thank you. |
Post Number: 142 Registered: Aug-07
| Posted on Saturday, February 23, 2008 - 08:29 pm: |
what about captiveworks is any1 getting star plus on captive works 600p |
Post Number: 8445 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 08:30 pm: |
A lot of work was done by Plymouth, Dizasta and Taran. |
Post Number: 4 Registered: Oct-07
| Posted on Saturday, February 23, 2008 - 08:31 pm: |
Thanks to Plymouth, Dizasta and Taran also. |
Silver Member Username: Kingofdakingz
Post Number: 169 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 08:33 pm: |
at my cousins house star plus is working but not at my house. we both have vs ultra receivers |
Quebec city,
Quebec
Post Number: 245 Registered: Jan-08
| Posted on Saturday, February 23, 2008 - 08:34 pm: |
IT,s a Pleasure for all on this forum |
New member Username: Mehul420
Post Number: 8 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 08:53 pm: |
all this talk is about STAR PLUS INDIA.... Is STAR SPORTS on ECHOSTAR 3 as well? |
Quebec city,
Quebec
Post Number: 247 Registered: Jan-08
| Posted on Saturday, February 23, 2008 - 08:55 pm: |
I dont think for now but later it's possible. This not now in service officially |
Post Number: 55 Registered: Jan-07
| Posted on Saturday, February 23, 2008 - 09:27 pm: |
i think if,and plymouth is saying yes, star plus becomes legit, we should see all the STAR channels coming to DN. next couple of weeks should be interesting |
Silver Member Username: Leafs
Post Number: 496 Registered: Oct-07
| Posted on Saturday, February 23, 2008 - 09:28 pm: |
anyone know exactly why Star plus is coming on DN... because they don't have a contract with DN as far as I know... |
Quebec city,
Quebec
Post Number: 250 Registered: Jan-08
| Posted on Saturday, February 23, 2008 - 09:33 pm: |
Richman Nali said the best answer this probably because the contract come over with Direct tv and Dish practice this new Indian |
Post Number: 497 Registered: Oct-07
| Posted on Saturday, February 23, 2008 - 09:37 pm: |
if there contract is over... then DIsh will win it easily... because DN has a better lineup of channels... |
Post Number: 100 Registered: Apr-07
| Posted on Saturday, February 23, 2008 - 10:07 pm: |
Trump - That means Dn will have monoploy on South Asian channels. DTV SUX comapred to DN. |
Silver Member Username: Lomna
Post Number: 149 Registered: Dec-07
| Posted on Saturday, February 23, 2008 - 10:10 pm: |
I don,t think star plus will ever use dn cuz they(star plus) are well aware of the dn,s signal security. |
Bronze Member Username: Leo_here
Post Number: 58 Registered: May-06
| Posted on Saturday, February 23, 2008 - 10:33 pm: |
Devin DN has 7 times the Indian subscription then DTV (Legal!) If you had an option to sell out STAR signals..who would you sell it to? DN rulezz! |
Post Number: 242 Registered: Jun-06
| Posted on Saturday, February 23, 2008 - 11:31 pm: |
i was just wondering, is any one getting the programe guide on star plus ? |
Quebec city,
Quebec
Post Number: 257 Registered: Jan-08
| Posted on Sunday, February 24, 2008 - 09:01 am: |
V This the official site: http://starplus.indya*com/ |
Silver Member Username: Vittu
Post Number: 164 Registered: Oct-07
| Posted on Sunday, February 24, 2008 - 10:21 am: |
what about 118? is it only on 61.5? |
Bronze Member Username: Harchi777
Surrey,
Bc
Post Number: 22 Registered: Oct-07
| Posted on Sunday, February 24, 2008 - 11:02 am: |
do i need to adjust the dish too. |
Post Number: 243 Registered: Jun-06
| Posted on Sunday, February 24, 2008 - 12:28 pm: |
thanks PLYMOUTH |
Post Number: 69 Registered: Nov-06
| Posted on Sunday, February 24, 2008 - 01:16 pm: |
I have to viewsat ultras at home. One is for 119,110 and 61.5 that is getting star plus. The other one is hooked up for just 61.5. The channel 605 is greek, and the channel called user channel is just black and says no signal, any ideas??? |
Post Number: 172 Registered: Jun-06
| Posted on Sunday, February 24, 2008 - 03:04 pm: |
yes i tried what ever the first post of this thread said and it works thanks alot guys |
Silver Member Username: Halo
Toronto,
Ontario
Post Number: 391 Registered: Oct-07
| Posted on Sunday, February 24, 2008 - 03:10 pm: |
i have pansat flu clone and i have tried the instructions many times tp 12443 20 000 H and then 5666,5667 and 5666 and still i am not getting the channel and i am scanning on echo/3 61.5 can some one plzzzz help thx for any replies |
Post Number: 8457 Registered: Jun-06
| Posted on Sunday, February 24, 2008 - 04:02 pm: |
Andrea: When you do that, you should get one channel - CH-A, with a channel No. 0 |
Quebec city,
Quebec
Post Number: 259 Registered: Jan-08
| Posted on Sunday, February 24, 2008 - 04:31 pm: |
Andrea you must do a blind scan |
Post Number: 244 Registered: Jun-06
| Posted on Sunday, February 24, 2008 - 04:43 pm: |
Andrea make sure that when you enter those numbers you have proper signal level and also make sure that you enter those numbers correctly |
Silver Member Username: Dghumman
Ontario
Post Number: 217 Registered: Feb-06
| Posted on Sunday, February 24, 2008 - 04:48 pm: |
i have viewsat pro and i just scanned 61.5 again and i got 2 605 channels and the first one was starplus. thanks for the info guys on this forum are very good thanks for the help. does anyone know how to get starplus on nfusion please help as i have tried everything that i could some help would be highly appreciated |
Quebec city,
Quebec
Post Number: 261 Registered: Jan-08
| Posted on Sunday, February 24, 2008 - 05:20 pm: |
Damindar (Nfusion)The problem is The frequency is not programmated in your receiver if you scan and the box not scan this freq just to bad. You must succeed to scan this freq. Good luck |
Silver Member Username: Pannu16
Post Number: 760 Registered: May-06
| Posted on Sunday, February 24, 2008 - 06:35 pm: |
Sonic view is not able to get this channel on tp scan and if i do it using some other way, there is no option of channel scan or add channel mannually!! Any help!! |
Bronze Member Username: Canadiandude
Post Number: 11 Registered: Jan-06
| Posted on Sunday, February 24, 2008 - 10:52 pm: |
ON PANSAT 2700, PANSAT 2700 CLONES AND PANSAT 2500/flu CONVERTED. Menu/Dish Setup/Advanced scan Select Echo 3 at 61.5 In TP menu, right arrow till 12443 H Down arrow to Video. Change Auto to 5666 Down arrow to Audio. Change Auto to 5667 Down arrow to PCR PID. Change Auto to 5666 Nalin tried that on Converted FLU..It didnt worked..any other settings }}} |
Post Number: 8480 Registered: Jun-06
| Posted on Sunday, February 24, 2008 - 10:57 pm: |
I tried - at first it did not work and then tried again it worked and is working. |
Post Number: 12 Registered: Jan-06
| Posted on Sunday, February 24, 2008 - 10:59 pm: |
so after setting up these changes.wat do u do...continue with advance scan or has to blind scan |
Post Number: 8481 Registered: Jun-06
| Posted on Sunday, February 24, 2008 - 11:02 pm: |
Continue with just that TP - make the changes for 12443 H and then press OK and you will get one channel CH_A. |
Post Number: 13 Registered: Jan-06
| Posted on Sunday, February 24, 2008 - 11:05 pm: |
yes but this ch_a is blank....nothing comes on screen? and than it shows scrambled or bad channel |
Post Number: 8484 Registered: Jun-06
| Posted on Sunday, February 24, 2008 - 11:14 pm: |
That happened to me first time round. I persisted and it came through. Also try 12442 |
Post Number: 8485 Registered: Jun-06
| Posted on Sunday, February 24, 2008 - 11:18 pm: |
Also try switch off at the back and on again after 30 seconds. |
Post Number: 14 Registered: Jan-06
| Posted on Sunday, February 24, 2008 - 11:19 pm: |
i tried it like 7-8 times no luck....i dont show 12442..its either 12428..12443..or 12457 15 plus |
Post Number: 15 Registered: Jan-06
| Posted on Sunday, February 24, 2008 - 11:24 pm: |
anyhow...thanks nalin...will try tomorrow..again |
Quebec city,
Quebec
Post Number: 265 Registered: Jan-08
| Posted on Sunday, February 24, 2008 - 11:32 pm: |
X factor do you have this channel on save transponder: 7776 PBS-PROVIDENCE 12443 20000 h 5/6 7775 UPN-PROVIDENCE 12443 20000 h 5/6 7773 FOX-PROVIDENCE 12443 20000 h 5/6 7772 NBC-PROVIDENCE 12443 20000 h 5/6 7771 CBS-PROVIDENCE 12443 20000 h 5/6 7770 ABC-PROVIDENCE 12443 20000 h 5/6 If not reply |
Post Number: 150 Registered: Dec-07
| Posted on Sunday, February 24, 2008 - 11:42 pm: |
just wondering ..why dk,s website doesn,t any info about star plus? |
Quebec city,
Quebec
Post Number: 267 Registered: Jan-08
| Posted on Monday, February 25, 2008 - 12:05 am: |
We dont know, one thing is sure it's dish on frequency of dish. I thing Star gone to be presented possibly. |
Post Number: 16 Registered: Jan-06
| Posted on Monday, February 25, 2008 - 07:07 am: |
hi plymouth..I dont have these channels at echo 3 ku at this frequency 12443 i have following channels instead 7938 til 7944 and than from 8171-8179 onwards |
Quebec city,
Quebec
Post Number: 278 Registered: Jan-08
| Posted on Monday, February 25, 2008 - 07:49 am: |
X Sorry i dont know Pansat. Do you have like viewsat a "blind scan" or same. Try it but dish not emit the signal for detect this channel. try also to delete this sat and put the channel and autoscanin this order. Good luck |
Quebec city,
Quebec
Post Number: 279 Registered: Jan-08
| Posted on Monday, February 25, 2008 - 07:50 am: |
X Sorry i dont know Pansat. Do you have like viewsat a "blind scan" or same. Try it but dish not emit the signal for detect this channel. try also to delete this sat and put the channel and autoscan in this order. Good luck |
Post Number: 8530 Registered: Jun-06
| Posted on Monday, February 25, 2008 - 03:59 pm: |
x-factor: You can create any TP on a Pansat- Do to the Edit TP at the bottom of the Dish menu. |
Bronze Member Username: Saadiaa
Post Number: 69 Registered: Nov-07
| Posted on Monday, February 25, 2008 - 04:03 pm: |
It also works with tp 12441 for converted flu's |
Bronze Member Username: Cooll
Post Number: 24 Registered: Mar-07
| Posted on Monday, February 25, 2008 - 05:55 pm: |
i m not getting any signal on 12441 12442 and 12443 tp so it doesn't even scan on these tp any idea why i have pansat 2700 converted i am getting all the other channels i mean they are down but i am getting the signal any suggestion |
Bronze Member Username: Lionking
Post Number: 52 Registered: Jun-06
| Posted on Monday, February 25, 2008 - 06:36 pm: |
i did scan that channel but it still says scrambled on flu converted |
Post Number: 70 Registered: Nov-07
| Posted on Monday, February 25, 2008 - 06:41 pm: |
U must have done something wrong... redo the process..I I have a converted FLu ..it works fine for me  |
Post Number: 25 Registered: Mar-07
| Posted on Monday, February 25, 2008 - 06:43 pm: |
dude it might work on a diffenet tp for you for me it was 11940 H which i belive is either the fifth or the sixth tp from the beginning for me any way just try in the starting tp for H polarity it might work for you. |
Post Number: 26 Registered: Mar-07
| Posted on Monday, February 25, 2008 - 06:50 pm: |
lionking try to find the tp for the following channel WLNE, WPRI, WJAR, WNAC , WLWC, WSBE, the tp should be the same for all of these now on thses tp write video PID and all that then scan it should work or else keep trying on diff tp. |
Bronze Member Username: Jppatelahd
Post Number: 61 Registered: Sep-07
| Posted on Monday, February 25, 2008 - 07:23 pm: |
i have captive works i do advance scan and enter the value of video, audio and PCR but after i press OK than my box hangs up..and than i have to swich off from back and starts again.. i did it five times but no results.. can any one help me to get star plus on captive works 600s premium. |
Post Number: 63 Registered: Sep-07
| Posted on Monday, February 25, 2008 - 07:27 pm: |
i also did a tp scan on that tp i got only these channels : WLNE, WPRI, WJAR, WNAC , WLWC, WSBE but not star plus.. any help please.. |
Post Number: 8535 Registered: Jun-06
| Posted on Monday, February 25, 2008 - 07:31 pm: |
FOR PANSAT 2700 AND CLONES AND CONVERSIONS: It is in plain and simple English. YOU CAN CREATE ANY TP NUMBER UNDER ANY SAT BY GOING INTO MENU/DISH SETUP/EDIT TP/SATELLITE. |
Post Number: 64 Registered: Sep-07
| Posted on Monday, February 25, 2008 - 07:43 pm: |
nalin help me please??? |
New member Username: Chirut
Post Number: 5 Registered: Oct-07
| Posted on Monday, February 25, 2008 - 07:45 pm: |
is it work for 118 |
Bronze Member Username: Mucho
Post Number: 70 Registered: Dec-07
| Posted on Monday, February 25, 2008 - 07:54 pm: |
Enjoy it, will not be here long only a test. You simple dump towel heads. In the USA everything is not Free unless you steal it. |
Gold Member Username: Satgrl
Ðïl Mêïñ ÐårÐ §å Jågå ...
Post Number: 1510 Registered: Oct-07
NEGATIVE becus this is not working on SV 4000 61.5 i did blind scan tp scan and satellite scan i dont think there is no other type of scan..... |
Post Number: 8543 Registered: Jun-06
| Posted on Monday, February 25, 2008 - 07:56 pm: |
jignesh: All the receivers except CW have Star Plus. I specifically asked Bruce 1, a CW guru to help and so far he has not come up with the answer. This is the thread – watch the thread if he does find it http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/452479 |
New member Username: Nbpanjwa
Post Number: 2 Registered: Feb-08
| Posted on Monday, February 25, 2008 - 08:02 pm: |
No, it is not working on Co*lsat 5000 too. Anyone, any luck with Co*lsat????? |
Post Number: 65 Registered: Sep-07
oh thanks a lot nalin |
Silver Member Username: Vic123
Toronto Canada
Post Number: 109 Registered: Jul-06
| Posted on Monday, February 25, 2008 - 08:04 pm: |
jignesh u gujrati |
Post Number: 72 Registered: Dec-07
| Posted on Monday, February 25, 2008 - 08:12 pm: |
Registered: Dec-07 Posted on Monday, February 25, 2008 - 07:54 pm: -------------------------------------------------------------------------------- Enjoy it, will not be here long only a test. You simple dump towel heads. In the USA everything is not Free unless you steal it. |
Post Number: 68 Registered: Sep-07
| Posted on Monday, February 25, 2008 - 08:13 pm: |
why?? |
Post Number: 8550 Registered: Jun-06
| Posted on Monday, February 25, 2008 - 08:16 pm: |
I think African had a post about it for C00LSAT, and he says it works. |
Post Number: 73 Registered: Dec-07
| Posted on Monday, February 25, 2008 - 08:32 pm: |
Nalin I am talking about USA Not African. |
Toronto Canada
Post Number: 110 Registered: Jul-06
| Posted on Monday, February 25, 2008 - 08:35 pm: |
jignesh u guju |
Silver Member Username: Dharm_ram
Post Number: 126 Registered: Dec-07
| Posted on Monday, February 25, 2008 - 08:46 pm: |
Hi Nalin / African..... can anyone confirm if we can get it on echo7 119 on VSU??? pls. give the settings..thx |
Post Number: 28 Registered: Mar-07
| Posted on Monday, February 25, 2008 - 08:54 pm: |
nalin can u tell me how did u figure this out i mean how come there's a channel like this also i found 2 other channels by doing the same thing except that i dunno wht language they are in also there's a specific patten in Video PID and the other PID that's how i found the other 2 channels but have no idea wht's going any clues?????????????????????? |
New member Username: Shehbazt
Post Number: 1 Registered: Feb-08
| Posted on Monday, February 25, 2008 - 09:07 pm: |
hey cool ^^^, how did you find the other channels? whats the pattern? |
Bronze Member Username: Cooljo
Post Number: 29 Registered: Oct-07
| Posted on Monday, February 25, 2008 - 09:32 pm: |
hello, please can any one tell me..how do i confirm that my Echo 3 is at 61.5 . For my pansat 2007a i did everything as nalin / xfactor suggested ..i got the 0 ch A ..but its blank ..want to know if 61.5 is right..please some one tell me... |
Bronze Member Username: Mshah2006
Mississauga,
Ontario
Post Number: 53 Registered: Jan-06
| Posted on Monday, February 25, 2008 - 10:03 pm: |
Thank you Nalin, I got StarPlus working on LTU. |
Surrey,
Bc
Post Number: 23 Registered: Oct-07
| Posted on Tuesday, February 26, 2008 - 02:54 am: |
can any body pl tell me ,do i need to adjust the dish too for getting echo 3 and 61.5 or i just follow the above said steps on my vs ultra for star plus. thanks |
New member Username: Attiss
| Posted on Tuesday, February 26, 2008 - 06:43 am: |
i m getting this ch_a on T/P 12433......but it's still black.i scaned it so many times but it's not working some body please help me i have pansat 3500. |
Bronze Member Username: Koolkuttu87
Post Number: 12 Registered: Dec-07
| Posted on Tuesday, February 26, 2008 - 07:09 am: |
i get the channel on 0000 but when i key in 0000 on the remote control it doesnt go to dat channel it simply stays on the current channel..does anybody knw how to renumber the channel or move it??? |
New member Username: Swetjay
Post Number: 5 Registered: Sep-07
| Posted on Tuesday, February 26, 2008 - 08:59 pm: |
I got Pansat 2700A and got STAR PLUS on T/P 11940 H Down arrow to Video. Change Auto to 5666 Down arrow to Audio. Change Auto to 5667 Down arrow to PCR PID. Change Auto to 5666 THANKS cool, your the man, THANKS Nalin for all your help buddy, you r doing just great keep it up |
Post Number: 553 Registered: Mar-06
| Posted on Tuesday, February 26, 2008 - 09:04 pm: |
STAR PLUS WORKS ON NFUSION Here's Hows to add STARPLUS On you Nfusion (Only Satellite 61.5) 1. Go to Installation 2. Go to Channels Scan. 3. Go to Add TP (last option) 4. Choose as below Frequency: 12443 Polarization: Auto Symbol Rate: 20000 5. Then go to Add channel. (choose as below) Channel Name: Star Plus (or any, doesnt matter) Video PID: 5666 Audio PID: 5667 PCR PID : 5666 6. Press Manu Two Times and it will same channel on memory. 7. Press Guide and choose channel No. 605 8. DONE! you will see guide in other language, but you will see its "STAR PLUS" |
New member Username: Chat7
Post Number: 2 Registered: Aug-07
| Posted on Tuesday, February 26, 2008 - 09:09 pm: |
you can watch all desi channels at this url on your computer, it is all free, no need for a fta reciever http://odesitv.blogspot.com/ Click on any icon and watch your favorite desi channel. |
Silver Member Username: Frobi
Post Number: 200 Registered: Aug-06
| Posted on Tuesday, February 26, 2008 - 09:41 pm: |
I tried several times on Viewset Extreme, but failed. Can some one please tell me step by step how to get Star plus? Thanks |
Bronze Member Username: Nusrat
Post Number: 30 Registered: May-06
| Posted on Wednesday, February 27, 2008 - 01:00 am: |
thanx..i got it working on mine aswell |
Post Number: 3 Registered: Feb-08
| Posted on Wednesday, February 27, 2008 - 07:56 am: |
still black for me 3500sd.........HELP please |
New member Username: Devang1987
| Posted on Wednesday, February 27, 2008 - 10:01 am: |
i see that people have been getting it on frequencies in the proximity of 12443...... how do they do that?? If I run a blind scan....technically it shud list out all the possible TPs right..... and all the possible channels???? I did that and didn't see CH_A or channel 0000 or 605.... I am pretty sure I have 61.5...once again FLU to 2700.. |
Post Number: 6 Registered: Oct-07
| Posted on Wednesday, February 27, 2008 - 10:08 am: |
i have to get this channel....it bothers me a lot when i cant get something that others can...lol |
New member Username: Crazycool
Post Number: 8 Registered: Jan-08
| Posted on Wednesday, February 27, 2008 - 11:58 am: |
Nalin I have a question for you right now I am using echo4 and echo7 and I'm getting all the channels that I need, now if I scan this star plus that everyone is talking about do I lose all my current channels and what is the benefit of star plus I've been in the fta game for almost 5 years Istarted with a pansat 2500a which I still have I converted it to a 2700 and I also have 2700a originals and 3500sd and the support for pansat rceivers have always been there and I thank blacklist for all of his support. |
Post Number: 8594 Registered: Jun-06
| Posted on Wednesday, February 27, 2008 - 06:25 pm: |
If you do a TP scan directly or through advanced scan, you don't lose anything, and if you follow the instructions properly you will ADD Star Plus. |
Post Number: 75 Registered: Dec-07
| Posted on Wednesday, February 27, 2008 - 07:03 pm: |
Nalin It does look like the party is over for you LK is here. |
Post Number: 8 Registered: Oct-07
| Posted on Wednesday, February 27, 2008 - 07:31 pm: |
ok finally got it working the clue i got was to look for the frequency of the 7777 series W channels....and then use that frequency instead of 12443 |
Surrey,
Bc
Post Number: 25 Registered: Oct-07
| Posted on Thursday, February 28, 2008 - 12:19 am: |
do i need to do the factory default first and then start the procedure as told in the begining of this forum.i have vs ultra.pl help |
Surrey,
Bc
Post Number: 26 Registered: Oct-07
| Posted on Thursday, February 28, 2008 - 01:12 am: |
for star plus ,when i do scan echo 3 i get all the channals with good signal(in the auto scan).but when i save and exit, my vs ulra keeps on running on 1,2 echo 148.i did it several times but same thing happen. pl tell me 1.do i need to adjust the dish too and get the signal first and then do the above procedure |
Gold Member Username: Kirankumar
Kenya
Post Number: 1801 Registered: Oct-07
| Posted on Thursday, February 28, 2008 - 02:37 am: |
Singh Saheb,if you are on 148 then you need to adjust the dish to 61.5 if you need help with dish adjustments go to www.dishpointer.com |
Surrey,
Bc
Post Number: 27 Registered: Oct-07
| Posted on Thursday, February 28, 2008 - 12:01 pm: |
thankx my dear. |
New member Username: Jalva
Smithtow,
New York
Post Number: 1 Registered: Mar-08
| Posted on Saturday, March 01, 2008 - 03:43 pm: |
Trying to get Star + manually on 3500SD but getting blank screen! i followed the same way Menu/Dish Setup/Advanced scan Select Echo 3 at 61.5 In TP menu, right arrow till 12443 H Down arrow to Video. Change Auto to 5666 Down arrow to Audio. Change Auto to 5667 Down arrow to PCR PID. Change Auto to 5666 NOT WORKING!!!! |
Silver Member Username: Thakkar2000
Post Number: 196 Registered: Jun-06
| Posted on Saturday, March 01, 2008 - 05:06 pm: |
FLU's not saving it..it disappers |
New member Username: Jainivas
Post Number: 3 Registered: Sep-07
| Posted on Saturday, March 01, 2008 - 05:17 pm: |
I tired doing the same on my Viewsat but it doesnt work....getting a blank screen. |
New member Username: Eelo
| Posted on Saturday, March 01, 2008 - 05:59 pm: |
mine was working before but i am getting black screen now i have panset 3000 plzz help me to get star plus |
Bronze Member Username: Saaju
Post Number: 11 Registered: Sep-07
| Posted on Saturday, March 01, 2008 - 06:34 pm: |
i have the same ploblem as Mac on mu viewsat ultra |
Post Number: 6 Registered: Sep-07
| Posted on Saturday, March 01, 2008 - 07:39 pm: |
Hi Guys, I have viewsat extreme box and followed Taran's guideline to get the Star Plus channel...but it didnt work for me. I get" No Audio No Video " msg and a blank screen. Can you please help.. Thank You, Bhaumik |
Quebec city,
Quebec
Post Number: 479 Registered: Jan-08
| Posted on Saturday, March 01, 2008 - 08:07 pm: |
Sorry guy i think Dn disconnect Starplus on this freq. We can try to search where it's gone but with no data for this channel it's very difficult. |
Post Number: 152 Registered: Aug-07
| Posted on Saturday, March 01, 2008 - 08:10 pm: |
is it true that star plus is gone |
Smithtow,
New York
Post Number: 2 Registered: Mar-08
| Posted on Monday, March 03, 2008 - 01:58 pm: |
Anyone was able to find the star plus or it's gone from DN? Thanks, |
