Home > Message Board > Home Video > Satellite TV > Archive through February 22, 2008 > Fortec lifetime ultra
Author Thread: Fortec lifetime ultra
Username: Fatback
is there any support for a fortec lifetime ultra or is it scrap??
Username: Nydas
Post Number: 8327
Have you just woken up?
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest Jvvh Fortec-2500_Can_Am_251.bin
and Jvvh_251_Nkk BINs included.
Also available separately in jvvh_251_and_others.zip file.
Reported working with BEV as of Feb20/2008 7.30 Eastern
Some jtag files are also included.
The full kit is in full_kit251E.zip or later. Download and unzip in a new jvvh directory.
Read the instructions in the Instructions.doc file.
http://public.box.net/2500_full_kit
Username: Desi_munda
Post Number: 115
i have flu to pansat converted, each time i put new bin, i have to do first Blind scan and after Satellite scan, it take much time, i want to know how to fix this problem, (i mean) i dont want to blind scan and satelite scan. i want when i put new file, it should work without scan.
i have one friend, he have the same receiver like me, flu to pansat converted. when he put the new file in, he can watch whitout scanning.
is there anybody who can tell me about this please??
Username: Nydas
Post Number: 8329
You can use Channel Master. Download it from
http://www.sharpc.com
It has good instructions. The main thin you have to know is thta although you have a Pansat 2500 converted, in the eyes of CM you have a Pansat 2700 or 3500 in the software. You still use the Straight RS232 cable.
Username: Lochness90
I used to use gtool to backup channels first, then update the new bin. Once new bin updated, then download the backup channels to the receiver again. Lately I got lazy, blind scan is much faster.
Home > Message Board > Home Video > Satellite TV > Archive through February 22, 2008 > Fortec lifetime ultra [ « Previous ] [ Next » ]
