Home > Message Board > Home Video > Rear Projection TVs > Archive through March 16, 2008 > Samsung dlp trouble
Author Thread: Samsung dlp trouble
Username: Stanman00
Hamilton, Ontario
here is my story i m in canada and bought a samsung hls6186w dlp tv from leons ive had this tv for 14 months did not get extendid warranty big mistake that will never happen again one night it just shut off i tried to turn back on heard a squeeling from it tried to turn itself on a couple of times but no go then just shut off so i waited a bit say 10 min i turned it on and it worked picture came but then it just went black still had sound for a few seconds then it shut off tried to turn back on heard the squeeling again tried to turn itself on again a couple of time then off changed the lamp same thing so icall tech he comes says its the lamp so he tries to change it quess what didnt work what goof this clown was now its a color wheel ballast and lamp hes says all by just listening to it cant belive all three parts are bad tried to get some help from samsung but there goofs too wont help at all tvs only 14months im gonna fix it myself any help would be greatthanx
Username: Tphanich
San Diego, CA
US
Totally sounds like the color wheel. A friend had the same problem and had to replace the color wheel and housing. A good website for that is SamsungParts.com or Discount-Merchant.com. It definitely doesn't sound like the lamp. The tech you talked to is trippin'. Color wheels are like 90 bucks or so, lamps a litte more, so I'd try the color wheel before the lamp.
Home > Message Board > Home Video > Rear Projection TVs > Archive through March 16, 2008 > Samsung dlp trouble [ « Previous ] [ Next » ]
