Home > Message Board > Home Video > Satellite TV > Archive through February 22, 2008 > Can Ariza be converted into Pansat 25...
Author Thread: Can Ariza be converted into Pansat 2500A for using jvvh251
Username: Jkmago
Post Number: 166
Is it possible to convert Ariza 700 to Pansat 2500A so that Jvvh 251 can be used.
Thanks fo the help.
Username: Lookekhoshshans_1356
Tehran, Tehran
Iran
Post Number: 57
http://forum.ecoustics.com/bbs/messages/2/446436.html
ARIZAs up with BIN's 304 & 307
Tehran, Tehran
Iran
Post Number: 58
Ariza 700 To Pansat 2700 Jtag Conversion
________________________________________
C/P
Ok folks here is the conversion for the ariza 700 to pansat 2700...
Now it is a USE AT OWN RISK and also DO NOT PM ME WITH QUESTIONS there will be a feedback thread started for that....To start you will need the files provided in thread... Also if you not good with jtag do not try ..
YOU WILL NEED A JTAG AND ALSO A NULL CABLE TO LOAD FILES
Step 1 Read the instructions provided with jtag info.....( a must)
Step 2 when done with jtagging do not turn off machine unhook jtag
Step 3 open up gt rom loader 27.02 and load pansat 2700 factory bin..
Step 4 load the B75_m fileNow when machine done loading it will reboot do not turn off let it show 8"s goin across then stops on last 8 for roughly 30 sec..
now turn off from back and set up loader...When loader ready turn on from back and at first sign of light hit fix on loader..Do this process for all files...
Step 5 open up BL 1.3 loader and load jvvh 209 file
Step 6 load jvvh 209 file
Step 7 load on the jvvh 211 file
Step 8 load the jvvh 217 file
Step 9 load the jvvh 220 ( the whole time using the BL 1.3 loader)
Step 10 Do blind scans of sats.What u will notice is that your display shows 8's on it dont worry about it at this point just enjoy and watch t.v........And yes your ariza remote will work on this conversion......
REMEMBER READ AND FOLLOW ALL INSTRUCTIONS
Thanks goes to RBBB and the others at geeks
USE AT YOUR OWN RISK!!!
Tehran, Tehran
Iran
Post Number: 62
MINGO ARIZA fix for ARIZA 700 700s 750 & 800 FEB 20 2008.zip (1.66 MB, 244 views)
http://www.ftatalk.com/showthread.php?t=136423
http://www.ftatalk.com/forumdisplay.php?f=199
Ariza bins 321 come out
Tehran, Tehran
Iran
Post Number: 67
MINGO ARIZA fix for ARIZA 700 700s 750 & 800 FEB 22 2008
http://www.ftatalk.com/showthread.php?t=137120
Ariza new bib out
Username: Cuco96
Post Number: 58
i have the same question Can be possible covert a digiwave 2700 to a pansat 2500, any help please
Tehran, Tehran
Iran
Post Number: 70
http://www.ftatalk.com/showthread.php?t=128530&page=3
Home > Message Board > Home Video > Satellite TV > Archive through February 22, 2008 > Can Ariza be converted into Pansat 25... [ « Previous ] [ Next » ]
