Thread: Samsubg DLP HLR-4266W Issue |
New member Username: Rdp3
Post Number: 1 Registered: Feb-08
| Posted on Monday, February 11, 2008 - 10:51 pm: |
I poured through several threads both active and in the archive and didn't see anyone with my model having the issues I am experiencing, so I thought I would start a new thread in the hopes of finding someone smarter than I to help me! Simple issue: Screen looks all filled with what would appear like a bad connection. Sort of like you would have on a crappy analog connection. Works this way when I connect my 360 to it and the menus behave exactly the same. Hard to describe, but all colors seem present but have a bunch of speckles in them and don't sit still. I read somewhere else that someone thought it was the digital module (board?). That's a pricey part to put in here...even if I can figure out how to do it myself. Any thoughts? If it is that digital board thingy, is it worth $500 and my time to replace or should I be considering a new something to replace it? Thanks in advance!! |
New member Username: Adelauney84
Post Number: 9 Registered: Feb-08
| Posted on Wednesday, February 13, 2008 - 04:03 pm: |
It sounds like it could either be the Digital Module Board or your Power Supply. I'm not sure if its worth fixing, but i know www.discount-merchant.com has DLP parts for MUCH cheaper than most places, so you may want to see if they have either part there first. Good luck! |
New member Username: Tphanich
San Diego,
CA
US
Post Number: 9 Registered: Dec-07
| Posted on Thursday, February 21, 2008 - 11:45 am: |
It does sound like the DMD. I don't know about the power supply though. Anabelle-- Are you the same anabelle from takingstuffapart.com??? |
