Thread: Gray band running down the right side |
New member Username: Nickster
Post Number: 2 Registered: Jun-05
| Posted on Thursday, January 31, 2008 - 11:02 am: |
My Samsung DLP 61" HLS6187WX/XAA has a 3" gray band running down to a 2" gray band on the right side of my screen. It's not completely dark but appears as gray and is disturbing when viewing movies. What to do? |
Relevant Product Info
New member Username: Adelauney84
Post Number: 3 Registered: Feb-08
| Posted on Saturday, February 09, 2008 - 02:13 pm: |
You might want to look at your light engine, that might be whats causing the problem you're experiencing. |
Bronze Member Username: Tphanich
San Diego,
CA
US
Post Number: 11 Registered: Dec-07
| Posted on Thursday, February 21, 2008 - 11:48 am: |
Sounds like a probably with the DMD or light tunnel. Have a repair guy check that out for sure! It may be costly either way--if it's still under warranty, I'd start there. |
Post Number: 3 Registered: Jun-05
| Posted on Wednesday, March 05, 2008 - 09:40 am: |
I'm past warranty. How costly is costly? Is it in the thousand range or hundreds range? |
Post Number: 4 Registered: Jun-05
| Posted on Saturday, March 29, 2008 - 05:40 pm: |
My Samsung DLP 61" HLS6187WX/XAA now has no picture but has sound. Using DishNET. No problem with video or sound when playing a DVD. My other CRT tv has sound and video with no problem from DishNET. Any ideas? |
Post Number: 6 Registered: Jun-05
| Posted on Saturday, March 29, 2008 - 06:39 pm: |
Also, I can't play the recorded shows on DVR on the DLP. |
