Thread: Nalin Help Please : B..7..5 |
Bronze Member Username: Devenw
MISIS
Post Number: 51 Registered: May-06
| Posted on Monday, January 28, 2008 - 08:57 pm: |
I`m keep getting message on my Pansat 2500 to 2700 converted. After i download new bin 245 x-87bl_080126_b75_245_api |
Silver Member Username: The_coders
Post Number: 192 Registered: Jan-08
| Posted on Monday, January 28, 2008 - 08:58 pm: |
why are you posting twice ? |
Post Number: 193 Registered: Jan-08
| Posted on Monday, January 28, 2008 - 08:59 pm: |
why are you posting twice ?? |
Gold Member Username: Cartier1
Post Number: 1718 Registered: Feb-07
| Posted on Monday, January 28, 2008 - 11:03 pm: |
the coders why r u answering him twice  |
Gold Member Username: Nydas
Post Number: 7730 Registered: Jun-06
| Posted on Tuesday, January 29, 2008 - 12:19 am: |
x-87bl_080126_b75_245_api is the original BIN by BL for genuine Pansat 2700. IT WON'T WORK ON A CONVERTED(2500/FLU to 2700) In fact, it may put it into deep coma. Download the full kit 14B, and after unzipping look at the revert to 2500 directory. follow the instruction in that directory to convert it back to 2500 and then convert and load the 245T_lightning BIN There are detailed instructions for conversion there. If it does not work, you may have to jtag. As long as there is light in the receiver, there is hope of an easy serial load solution without jtag. *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*- The full kit is in full_kit14B.zip. Unzip into a new jvvh directory. and read the instructions in the Instructions.doc file. http://public.box.net/2500_full_kit Download the kit and unzip in a new jvvh directory. Read the Instructions file. Or just download the 245 or 244 files. |
Post Number: 7738 Registered: Jun-06
| Posted on Tuesday, January 29, 2008 - 11:06 am: |
bump |
