Home > Message Board > Home Video > Satellite TV > Archive through January 29, 2008 > Can I get 97 110 and 119 on one 33"...
Author Thread: Can I get 97 110 and 119 on one 33" dish
Username: Book77
Post Number: 129
I realize i need a different LNB's but what about reception.
Username: Nydas
Post Number: 7727
You should be able to get them.
You can even try three dual LNBs like
97, 110, 118.7/119
Username: Tapeman
New York City in-HD, NY
Post Number: 2279
33" impossible for one reason
97 must be at the center as it requires most Watt power
I don't think either a 36" can do
If it is possible will be at least one meter dish
But this is a perfect case for one Universal LNB, a 30" dish and a motor
I think a motor maybe best option now days for all types of satellites except for DTV 103 Ka band
Username: One_eye_jack
Post Number: 295
Jim
To answer your question, Yes you can get 97, 110& 119 0n your existing 33" Dish.You will need a Linear LNB for Galaxy 25 @ 97.o*W and a DishPro Twin LNB for 110 & 119.
C/P
Dish Network DishPro Twin LNBF (NEW): Use it to look at the 110 and 119 orbital locations, using a 20” (or "DISH 500”) dish antenna. The DishPro Twin LNBF can directly connect to two tuner inputs (either two "single tuner receivers” like Dish311, or one "two tuner receiver" like DishPVR 625). The DishPro Twin LNBF can connect to a DishPro DP34 switch, if more receivers, or additional orbital locations, are required in the installation. Circular type.
Username: Tapeman
Post Number: 2280
No Yukon
I'll bet yo $0.50 can't get all 3 with a 33" dish
Trust me
Username: Jurj1
Post Number: 511
King Tapeworm YO ARE A RETARD
Username: Tapeman
Post Number: 2281
Hey pulp
Globe Cast is 97W
The question is can yo get all three with one dish?
Are yo reading the question correctly?
Yo can get 97 and 110
I say very difficult all 3
If if yo think yo could, be my guest
Home > Message Board > Home Video > Satellite TV > Archive through January 29, 2008 > Can I get 97 110 and 119 on one 33"... [ « Previous ] [ Next » ]
