Home > Message Board > Home Video > Satellite TV > Archive through January 29, 2008 > I.F out question
Author Thread: I.F out question
Username: Enough_said
Post Number: 14
I have loaded many recivers with files but never been asked to I.F out to loop a legit receiver. When I hookrd up this new SV 4000 today the person wanted their real reciever (5900)to stay working as well so I looped it from the I.F out coming from the sonicview and it worked. After loading a bin to the SV the real reciver no longer gets a signal from the I.F out. Ant solutions using this or will I have to use a sw switch and will the bell receiver pick up a signal thru one of these switches since I can't tell it what port to pull from?
Post Number: 15
Any suggestions as I can't use a sw switch because I need two lines coming out not one.
Username: Vyizder_zomenimor
Post Number: 49
I think the if out may only be used when the SV unit is turned off.
Post Number: 16
Tried that but still no signal to the 5900
Home > Message Board > Home Video > Satellite TV > Archive through January 29, 2008 > I.F out question [ « Previous ] [ Next » ]
