Thread: Superdish setup |
Silver Member Username: Impala1977
Post Number: 186 Registered: Apr-06
| Posted on Sunday, January 27, 2008 - 02:39 pm: |
Guys, can anyone tell me what your antenna setup is for a superdish 121, I am using a pansat 2700. Thank you. |
Silver Member Username: Scabz
Knoxville,
Tn
Us
Post Number: 359 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 04:28 pm: |
I believe that your super dish has to be converted before you can get dn or bev. |
Gold Member Username: Nydas
Post Number: 7708 Registered: Jun-06
| Posted on Sunday, January 27, 2008 - 07:40 pm: |
121W is Echo 9. If you got it for International channels, they are being reduced. The settings depend upon your LNB type. |
New member Username: Wizzard2004
Post Number: 7 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 08:21 pm: |
so nalin, does tht mean tht u dont have to physically move the position of the satellite? cuz mines also pointing at 121 and i cant face it to get 65 cuz i live in an aptmt building and 65 is on the other side of the buildg |
Post Number: 7716 Registered: Jun-06
| Posted on Sunday, January 27, 2008 - 08:37 pm: |
If you are really looking for the Internationals., you can continue with what you have and either buy a Universal LNB for 118.7/119 (about $25) or buy a DN repointing kit for conversion to 118.7 (about $100). Then after changing angle by 2 degrees, do a setup first for 119 and then for 118.7 There are 3-4 threads in the last 1 week. Read them. |
Post Number: 187 Registered: Apr-06
| Posted on Sunday, January 27, 2008 - 08:40 pm: |
thanks for the responses, I am not sure what you mean by converted scabz, Nalin, Will they be reduced completely? Because that is why I got it for international, I was able to get 119 but 110 is gone and 121 has a strong signal and when I scan I get repeat channel and no internationals. This what i have- Superdish 121 dp34 switch 110- 11250, lnb dp,diseq 2 119- 11250, lnb dp,diseq 1 121- 10750, standard, diseq off |
Post Number: 188 Registered: Apr-06
| Posted on Sunday, January 27, 2008 - 08:43 pm: |
Nalin, read your post late. Thank you, i'll look around. |
Post Number: 7719 Registered: Jun-06
| Posted on Sunday, January 27, 2008 - 09:58 pm: |
Even if you are not buying from DN, you may talk with them and get all the info. |
Knoxville,
Tn
Us
Post Number: 360 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 10:02 pm: |
Sorry I have no clue to what I'm saying. |
