Thread: No Indian Channels with New Pansat Bin |
New member Username: Javjla
Post Number: 1 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 02:28 pm: |
Guys, I am not getting any indian channels with the new Pansat Bin for DN. Kindly help. |
Silver Member Username: The_coders
Post Number: 190 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 02:37 pm: |
same here , no cowboy channels either  |
Gold Member Username: Dude123
Post Number: 1963 Registered: Jul-06
| Posted on Sunday, January 27, 2008 - 02:46 pm: |
Which pansat receiver do you have? Which bin are you using? what satellites are you scanning? answer to these questions would be nice.... |
Post Number: 1964 Registered: Jul-06
| Posted on Sunday, January 27, 2008 - 02:47 pm: |
B3V or DN? All pansats should be up for B3V and DN....They released the latest file yesterday |
Post Number: 2 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 02:55 pm: |
Hello The one Following are the answers to your Questions- I am using Pansat 3500SD. 'X-05BL_080126_361_api_nocard(test)'is the BIN that I am using. I use to get all the indian channels in ECHO 3/Ku Satellite and now they are not coming. This issue is related to DN. Kindly help. |
Bronze Member Username: Imars99
BRAMPTON,
ONT
CANADA
Post Number: 44 Registered: Aug-06
| Posted on Sunday, January 27, 2008 - 02:57 pm: |
Delete all chennels and do blind scan. |
Post Number: 3 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 03:32 pm: |
I did the blind scan and I am still not able to get Indian channels. Kindly help. |
Post Number: 1965 Registered: Jul-06
| Posted on Sunday, January 27, 2008 - 03:57 pm: |
so you dont see the channels in your list or you see some kind of a message when you try to go to those channels? |
Post Number: 4 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 04:09 pm: |
I see the channels in my list as I use to before. But these channels are not working anymore. I get message as 'No Signal' or 'scrambled channel'. Kinldy help. |
Silver Member Username: Koko_wawa
Post Number: 203 Registered: Aug-07
| Posted on Sunday, January 27, 2008 - 04:21 pm: |
If you want to watch Indian channels you have to go to India to see them all |
Post Number: 1966 Registered: Jul-06
| Posted on Sunday, January 27, 2008 - 04:29 pm: |
did you try turning your box OFF from the back and then ON after a minute or so? |
Post Number: 5 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 04:39 pm: |
CAN YOU MIND YOUR WORK AND DONT BOTHER karkour kaka. |
Post Number: 6 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 04:48 pm: |
Hello The one I did try that and no result. Kinldy help |
Post Number: 1967 Registered: Jul-06
| Posted on Sunday, January 27, 2008 - 04:55 pm: |
the only thing I can suggest you is that try loading the bin file again and blind scan because 361 is the latest fix for B3V and D!SH.... |
Post Number: 204 Registered: Aug-07
| Posted on Sunday, January 27, 2008 - 04:58 pm: |
my friends there is an new ECM running in the stream right now and expect coplete bloackade soooon. This explains your problem with indian channels and the dark screen that will follow soon.DN will be down sooon |
Post Number: 1968 Registered: Jul-06
| Posted on Sunday, January 27, 2008 - 05:04 pm: |
kaka Dish is currently working with no problems...I am watching it right now. And it should work on 3500 as it is on 2700 |
