Thread: 82W please help |
New member Username: Smartboyveer247
Post Number: 1 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 01:01 pm: |
I am new to all of this and can someone please help me find 82W, what do I need to do. thanks I have a pansat 2700a |
Gold Member Username: Kirankumar
Kenya
Post Number: 1134 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:03 pm: |
is your dish aligned to 82W ? |
Post Number: 2 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 01:04 pm: |
no its aligned to 61W |
Kenya
Post Number: 1135 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:07 pm: |
you need to align your dish to 82w first. go to www.dishpointer.com |
Kenya
Post Number: 1136 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:11 pm: |
let me know if you need any more help |
Post Number: 3 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 01:12 pm: |
What is this? what do I need? Dish Setup Data Elevation:38.5° Azimuth (true): 196.5° Azimuth (magn.): 212.3° LNB skew: 11.9° |
Kenya
Post Number: 1137 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:15 pm: |
your dish needs to be adjusted to those settings so the dish would point at 82w satellite. if you are not good with this kind of stuff you might need an installer come and move the dish for you |
Post Number: 4 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 01:16 pm: |
ya but I live in USA,so those are the angles that i need to move the dish? |
Kenya
Post Number: 1138 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:18 pm: |
yes. tell me why want 82 w also when you move your dish you will lose 61.5 which carries international channels,is that what you want? |
Post Number: 6 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 01:25 pm: |
i have 2 sat dishes |
Kenya
Post Number: 1139 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:26 pm: |
so i guess you have 61.5 on one dish and 119 and 110 on the second dish right |
Post Number: 7 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 01:29 pm: |
no my friend just moved and he gave me his dish, i have one pointed to 61.5 and i want the other pointed to 82W |
Kenya
Post Number: 1140 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:33 pm: |
that is good, you will need to install that second dish as per dishpointer instructions,then you will need a switch,so you will have 2 cables coming from 2 sats to switch and 1 cable from switch to receiver |
Kenya
Post Number: 1141 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:35 pm: |
you will need a DisEqC switch |
Post Number: 9 Registered: Jan-08
ya i already have a switch i think its called a diseqc switch, this is what that site gave me Elevation:38.5° Azimuth (true): 196.5° Azimuth (magn.): 212.3° LNB skew: 11.9° what so i do with it? how do i know which way to turn the dish? |
Kenya
Post Number: 1142 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:37 pm: |
do you have a signal meter? |
Bronze Member Username: Smartboyveer247
Post Number: 11 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 01:39 pm: |
no |
Kenya
Post Number: 1143 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:44 pm: |
ok first you need to install your pole,this should be plumb (straight up)then on the dish adjust your elevation,there are markers there.then you will have to guess ,you should get 82 w if you point it to the right of your 61.5 and keep on moving it slowly until you lock in.it will take a lot of time |
Post Number: 12 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 01:46 pm: |
see i got 61W easily by using the dishnet receiver,you go to dish pointer and when you pick up the angle the thing goes green and when you dont have the angle the thing goes red, is there anything like that on a FTA receiver? |
Kenya
Post Number: 1144 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:50 pm: |
exactly, you got it,and make sure you see 82w on the top right hand corner |
Post Number: 13 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 01:54 pm: |
no i am asking it there sometihng like that on the pansat or nfusion? |
Kenya
Post Number: 1145 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 01:57 pm: |
it is on all fta receivers yes |
Post Number: 14 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 02:00 pm: |
ok thanks a lot man, what receivers do you have? |
Kenya
Post Number: 1146 Registered: Oct-07
| Posted on Sunday, January 27, 2008 - 02:03 pm: |
i have c00lsat 5000 6000 7000, if you follow my instructions you will be ok,if you have any more problems,i am at www.crazyfta i can help you there.good luck |
Silver Member Username: Dimwitt
Post Number: 385 Registered: Aug-06
use the quality meter in the antenna setup, for locking onto a sat. install dish and diseqc switch , do antenna settings for 82 with proper diseqc port and lnb type selected. use dishpointer.com , setup the google map for your dish location , aim as shown and adjust elevation till you get good quality |
Post Number: 15 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 02:08 pm: |
ok thanks a lot tooter and african |
Silver Member Username: Madflea168
Post Number: 153 Registered: Jan-08
| Posted on Monday, January 28, 2008 - 01:32 am: |
African, I have a dtv 3 lnb sitting on my roof, do you know if the lnb would work on bev? |
New member Username: Warbe
Post Number: 1 Registered: Feb-06
| Posted on Monday, January 28, 2008 - 09:20 pm: |
you can use your old dish recevier to find the signal from a bev sat(82 or 91) |
