Thread: Please heeeeeelp where r u guys |
Bronze Member Username: Tanhoura
Post Number: 24 Registered: Aug-07
| Posted on Sunday, January 27, 2008 - 01:18 am: |
i downloded bin 245 for pansat 2700 but all chanels are gone what do i have to do? i tried a blind scan but couldn t get PPV and when i tried to scan BEV my receiver turn off and the on please help thanks |
Silver Member Username: Extremex
Post Number: 158 Registered: Nov-07
| Posted on Sunday, January 27, 2008 - 01:22 am: |
Dang!! Relax!! Check your sat/switch settings. Sounds like they were reset. |
Post Number: 25 Registered: Aug-07
| Posted on Sunday, January 27, 2008 - 01:23 am: |
what do i have to do |
Post Number: 26 Registered: Aug-07
what do i have to and how to do it |
Post Number: 159 Registered: Nov-07
| Posted on Sunday, January 27, 2008 - 01:25 am: |
Well, I dont have a pansat so I cant give you the steps. But how did you set it up to begin with? You will need to know what LNBs/Switches you are using. |
Post Number: 27 Registered: Aug-07
| Posted on Sunday, January 27, 2008 - 01:26 am: |
well i dont know how should i know? |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 12803 Registered: Jun-06
| Posted on Sunday, January 27, 2008 - 01:38 am: |
Wow. |
Bronze Member Username: Jwl1
Post Number: 97 Registered: May-06
| Posted on Sunday, January 27, 2008 - 03:00 am: |
Lolita--when you get it all straightened out, for future references, write the settings down. That way, if this happens again, you will have them handy. |
Silver Member Username: Destine0429
Quebec
Post Number: 421 Registered: Dec-06
| Posted on Sunday, January 27, 2008 - 03:11 am: |
Check your Signal. Start off Menu Dish Set Up Satellite Scan Go to Nimiq 1, click ok Should bring you to the other side of the screen Shut off DISEQC if you are only using 1 satellite dish. Then go down to SCAN ALL. Click ok. WAIT FOR THE DOWNLOAD TO FINISH! Once that is done, exit to the Main Menu. Go to Channel Edit. Put in your Pin...most likely 0000 Click ok on Sort, Click OK on Alphabetical. Exit, click ok for saving. Exit all the way out to your tv. WAIT FOR KEYS TO ROLL. Should work |
Silver Member Username: Bushdaman
Post Number: 168 Registered: Nov-07
| Posted on Sunday, January 27, 2008 - 05:44 am: |
free tver what a pity. |
