Thread: Pansat 2700 bin 245 help |
Bronze Member Username: Tanhoura
Post Number: 23 Registered: Aug-07
| Posted on Sunday, January 27, 2008 - 12:59 am: |
i downloded bin 245 for pansat 2700 but all chanels are gone what do i have to do? i tried a blind scan but couldn t get PPV and when i tried to scan BEV my receiver turn off and the on please help thanks |
Bronze Member Username: Martinz
Post Number: 12 Registered: Dec-07
| Posted on Sunday, January 27, 2008 - 08:05 am: |
Lolita, Always download good known bins from Jvvh or CS. I found that marketrealm.com always have reliable bins and I never had any problems. They still don't have 245 so I wouldn't load it. I'll rather wait a day than screw the box. BTW, Jvvh_244 works for DN. |
New member Username: Bigmix
Spooner,
Wi
Post Number: 2 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 07:44 pm: |
This question for Nalin. Since you are a rock at this site that keeps some of the normal people here. Can you help me with a problem. I having a problem getting my pc to connect to a pansat2700a. I have windows xp with no serial port. Just bought a USB to Serial cable from radioshac mdl#26-183. Have com port adjusted on loader to proper port on pc. Loader says down loading but stays @ 0% until failing. I have not loaded a bin since last FEB. #295. I know I must upgrade to b75 loader but can not connect for results. Thanks for all your advise and insite over the years!! |
Gold Member Username: Nydas
Post Number: 7710 Registered: Jun-06
| Posted on Sunday, January 27, 2008 - 07:57 pm: |
lolita: If you have a genuine Pansat BIN use BL87 BINs from http://www.future-fta.info If you have a 2500-2700 conversion use the conversion 245 BIN either CS_245T_lightning or jvvh_245. The two types of BINs are NOT interchangeble. |
Gold Member Username: Dude123
Post Number: 1969 Registered: Jul-06
| Posted on Sunday, January 27, 2008 - 07:58 pm: |
I am not Nalin but I will put in my two cents since he hasn't answered yet.... Firts you must download the driver that came with the adapter, if it didn't come with one you have to go to the website and download it from there. After that you go to your device manager from your system's properties. click on: -com ports -then select your adapter from the list -right click and go to properties -then on the top, go to port settings -click on advance settings -change the com port to one that is not in use (1 to 4) and then you have to select that same one on the loader. GOOD LUCK! |
Post Number: 7711 Registered: Jun-06
bigmix. You probably have a RS232 straight cable. Get a DB9 M/F adaptor and use it in series with the rest of the cabling. |
Spooner,
Wi
Post Number: 4 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 08:16 pm: |
Nalin. At which point in the series of cables do I put the adapter? In between the USB to seria*l and the null cable? thank you for your reply Nalin and The One. |
Post Number: 7715 Registered: Jun-06
| Posted on Sunday, January 27, 2008 - 08:31 pm: |
You can put it anywhere along the line from the computer to the receiver. Remember I said DB 9 M/F adaptor This is a very good device to have if you have an unknown cable. With it NOT in the cable remains the original type. With it in, the cable becomes opposite type. |
Spooner,
Wi
Post Number: 5 Registered: Jan-08
| Posted on Sunday, January 27, 2008 - 08:53 pm: |
Thanks Nalin!! I will purchase one tomorrow. and advise of results. Again thank you for your help. The One--Thank you for your advise as well. It has givin me a better understanding on proper com port set up. Thank you! I look forward to reading your posts in the future as in the past. |
Post Number: 1972 Registered: Jul-06
| Posted on Sunday, January 27, 2008 - 09:00 pm: |
Pleasure! |
