Home > Message Board > Home Video > Satellite TV > Archive through January 29, 2008 > How to save channels?
Author Thread: How to save channels?
Username: Suketu90
Toronto, Ontario
Post Number: 20
How do i save channels on my pansat 2700 converted? so that i don't have to rescan everytime?
Username: Shadow45
Mty, Nuevo Leon
Mexico
Post Number: 253
Credit goes to JAVY_GARZA from the hispanic thread....
He posted a very easy way to DL your channel list to the pc..(in my case ,i have a lava3200 converted to pansat2700)
1. do a blind scan so u get all the channels
2. edit the channels..(what i did was erase all the crap i dont watch,need)and make sure the settings for your sats are correct.
3.plug the straight Fm to Fm db9 cable to your STB
4. open the X-87 27.02 loader and on "file type" select the "channel data file" option
5. with the receiver turned on and plugged in to the pc, click the already enabled "uupload" button
6. wait for it to say "complete" and save the channel list in the folder you want
to download it back to the stb once a new bin is loaded just reopen the X-87 loader.. wait for the stb to reboot and when it gets to the screen where it says "english" and hit "download"...again wait for it to say "complete" and there u go the channels and settings will be available from the start w/o needing to do a scan again.
hope it helps.
Username: Runnerguy
Pluto
Post Number: 1127
http://www.satelliteguys.us/free-air-fta-discussion/41202-pansat-2700a-gtool-cha nnel-editor.html
Username: Polo69
Post Number: 32
where i can find the X-87 27.02 loader
thanks for your help
Username: Vittu
Post Number: 128
I have seen some receivers where I do not have to reload the channel files. Channels stays there permanently. Where else on some receivers I have to setup the sats and blind scan manually. How so? I m talking about pansat/FLU converted to 2700.
Username: Vittu
Post Number: 129
Is it because I am using channel master to read/write and not Blacklist loader??
Username: Khopdi
Post Number: 84
Allow STB to fully boot and display a channel before download new bin. Just wait after turning on via backswitch till the receiver displays a channel number then start the download. After download the receiver will reboot to a channel and not the language screen.
Username: Vittu
Post Number: 134
thanks Khopdi. Is this nick taken from "Nukkad" :-)
Username: Polo69
Post Number: 33
khopdi
which loader are you using?
thanks
Username: Khopdi
Post Number: 85
X-05BL Loader v35 for PanSat 3500SD
Username: Famf555
I'm going to use Shadow45's method. Everytime I use channel master, it errors out at the end and will not read whats on the converted pansat 2700. It used to read it but not anymore.
Username: Rockman169
Post Number: 8
Home > Message Board > Home Video > Satellite TV > Archive through January 29, 2008 > How to save channels? [ « Previous ] [ Next » ]
