Thread: How to install 118.75° on VS Ultra? |
Silver Member Username: Xtrawest
BC
Post Number: 128 Registered: Nov-05
| Posted on Saturday, January 26, 2008 - 01:10 pm: |
118.75° is not available in VS Ultra Satellite List. Does anyone know how to add this location manually into the reciever?? |
Silver Member Username: Way2smart
DESIFTA .co.nr
Post Number: 718 Registered: Oct-06
| Posted on Saturday, January 26, 2008 - 01:31 pm: |
yaa same here try 119 ithink its the same dish..... try dishpointer.com |
BC
Post Number: 129 Registered: Nov-05
| Posted on Saturday, January 26, 2008 - 02:20 pm: |
is there any way to get Geo news and Aag TV on 119 dish? |
Silver Member Username: Madflea168
Post Number: 146 Registered: Jan-08
| Posted on Saturday, January 26, 2008 - 02:54 pm: |
actually, 121 work on me better than 119 or create a new anik/f3. you can change the lnb freq in 119/121 to 10600/10750 and add tp @11715. or by creating a new sat and enter the tp manually, some said need 5, but at least need 11715 to start. if you get signal/quality there, very much likely you will get the channels. it was a bit tricky for me to get 118, so good luck. btw, you will need antenna at least 30 inches and the 118 lnb, if you have super d, they have genuine dp repoint kit, I dunno if the generic will work on super d or not. minor antenna adjustment may needed. most of the international have moved to 118, soon all will. |
Gold Member Username: Nydas
Post Number: 7655 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 03:12 pm: |
Use a 33" Dish and special LNB CB2008A. I have posted a long post here: http://forum.ecoustics.com/bbs/messages/2/440503.html |
New member Username: Tonyg2000
Post Number: 4 Registered: Jan-08
| Posted on Saturday, January 26, 2008 - 03:14 pm: |
is there a bin for clone 2700 yet |
