Thread: No signal on second LNB |
New member Username: Rajman
Post Number: 6 Registered: Dec-07
| Posted on Saturday, January 26, 2008 - 12:17 pm: |
I have installed a second LNB (with Bracket) on a 18" dish. The original LNB pointing at 92 indicates 89% signal strength but the second one pointing at 81 shows 5% signal strength. Any ideas? |
Silver Member Username: Madflea168
Post Number: 139 Registered: Jan-08
| Posted on Saturday, January 26, 2008 - 12:25 pm: |
I think you said bev's 91 and 82. 91 and 82 individual are at different settings without the need of skew, when you put together in one antenna, it will be another setting AND skew. you will need some minor adjustment to the antenna. go google the sat calculator or there are some links on some of the fta sites. |
Post Number: 7 Registered: Dec-07
| Posted on Saturday, January 26, 2008 - 04:48 pm: |
Yes, I ment b3v's 91 and 82. Thank you, I'll try to move the dish so that i can optimize on both. Thanks again. |
