Thread: Please help |
New member Username: Dtag
Post Number: 6 Registered: May-07
| Posted on Saturday, January 26, 2008 - 10:42 am: |
i have a vsx2000 and loaded bin 080126 but still i'm getting " no audio or video " pop up on my channel info. i'm on bev. can some one help??? |
Silver Member Username: Madflea168
Post Number: 141 Registered: Jan-08
| Posted on Saturday, January 26, 2008 - 12:33 pm: |
you may lost all the infos in the box like some other members. did you try to set up the antenna and channels again? |
Bronze Member Username: Slimmaz
Post Number: 16 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 03:38 pm: |
need help my viewsatX is lock entered key 0000 but says wrong pin can help me please |
Post Number: 7 Registered: May-07
| Posted on Saturday, January 26, 2008 - 03:40 pm: |
i did a blind scan and still nothing???? please help!!!! |
Gold Member Username: Nydas
Post Number: 7658 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 03:41 pm: |
Many people are having problems with the latest 26th Jan BIN if scanning BEV. If you have ONLY BEV, use the 22Jan BIN. |
Bronze Member Username: Oscarman
Post Number: 30 Registered: Aug-06
| Posted on Saturday, January 26, 2008 - 04:09 pm: |
Anybody, help please I downloaded DBPSW-080126P to my VS plat. for DN...3 times from separate sites...only getting some cable channels. I double checked all keys. What's wrong? |
Gold Member Username: Donnie1973
Post Number: 2638 Registered: May-06
| Posted on Saturday, January 26, 2008 - 04:24 pm: |
make sure ur ant settings are correct |
