Thread: Any File for Converted Pansat Clone? |
Silver Member Username: Dishlover
Toronto,
Ontario
Canad
Post Number: 113 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 09:32 am: |
Where are JVVH or Chancysand's files for latest fix. Please advise. |
Gold Member Username: Brucester
Post Number: 1137 Registered: Jul-06
| Posted on Saturday, January 26, 2008 - 09:52 am: |
there not out yeat did you see them when you where overe at crazy tacking my files you pice of crap |
Toronto,
Ontario
Canad
Post Number: 115 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 09:58 am: |
Shutpup |
Gold Member Username: Nydas
Post Number: 7634 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 11:24 am: |
The Converted receiver files are usually 3-6 hours AFTER the main Pansat 2700 BIN is published. Keep an eye on future-fta.info site and when the new 2700 file is announced there, you can expect it 3-6 hours later. |
Toronto,
Ontario
Canad
Post Number: 116 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 11:55 am: |
Thanks Nalin. |
Post Number: 7640 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 12:05 pm: |
Tamara: Check you hostclip URLs elsewhere in the forum. They don't work. |
Silver Member Username: Espn3
Post Number: 221 Registered: Aug-06
| Posted on Saturday, January 26, 2008 - 12:09 pm: |
Nalin, Tamara, when the DN fix for the FLU converted to Pansat 2700 is available please post were it can be found. thanks. |
New member Username: Pch
Post Number: 1 Registered: Jan-08
| Posted on Saturday, January 26, 2008 - 12:21 pm: |
Hey Guys BEV bin 243 can be found at dsstester.c0m for BEV only - It works nice (-_-) good luck |
Post Number: 7642 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 12:32 pm: |
pe ce ech : You should understand that there are different BINs for Pansat 2700, clones and conversions. The question here is about conversion BIN, not the real Pansat 2700, and for DN ECM of 24th January. THERE ARE NO DN FIXES AVAILABLE YET FOR PANSAT 2700, 2700 CLONES, AND FOR 2500 TO 2700 CONVERSIONS. |
Post Number: 2 Registered: Jan-08
| Posted on Saturday, January 26, 2008 - 12:42 pm: |
Yes sir ! I understand very well I always read your message and used your INFO to convert my box to I of my pansat 2500 clone to 2700 I know that this site not alow the word dsstester.C0M but I just want to help whoever has the converted box like mine can watch BEV (Fortec or pansat remote bin 243 for BEV is working nice !!!!) Anyway If I made you and anyone here upset please fogive me (-_-) |
Post Number: 7645 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 12:50 pm: |
dsstester site has had too many false BINs posted there, even as recently as 4 weeks ago. That's why I would urge caution. |
New member Username: Tonyg2000
| Posted on Saturday, January 26, 2008 - 02:03 pm: |
Is the pansat 3500 bin the same as the quantum 3500. |
| Posted on Saturday, January 26, 2008 - 02:15 pm: |
is there a bin for that yet |
Post Number: 3 Registered: Jan-08
| Posted on Saturday, January 26, 2008 - 02:19 pm: |
OK Nalin a cheap person like me I always USE cheap Stuffs as long as I know where to get them By the way I sory to use the word DESSTESTER.C0M try to type the word dsstester.C0M into this forum see if you could do it Bye and good luck I beg your peace ! Pe ce ech (-_-) |
Post Number: 7652 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 02:46 pm: |
Pe ce ech: Don't worry. Everything is fine. There are few sites that Ecoustics does not like because of many user complaints. Then they do not allow the name in full, and people get around it by using names that are close to it (the way you did) or sometimes they use * instead of . and sometime they use the word "dot" instead of . |
Bronze Member Username: Zeez
San Mateo,
CA
Post Number: 16 Registered: Dec-07
| Posted on Saturday, January 26, 2008 - 02:51 pm: |
Nalin Nyda, you are always a great help to everyone ... thank you |
Post Number: 4 Registered: Jan-08
| Posted on Saturday, January 26, 2008 - 04:54 pm: |
hi hi hi ... very cool Nalin have you try that bin 243 for bev yet I watch TV since 24th Try It my friend ! It's free, You have nothing to loose ... packet it up and send it to your data warehouse and share with your fans I am your fan too in this site ! By the way my name pe ce ech in some language mean Uncle FROG - I jump I don't walk (-_-) |
Toronto,
Ontario
Canad
Post Number: 117 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 04:59 pm: |
If those links not working these can be found at dssworld. |
Post Number: 7669 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 05:52 pm: |
pe ce ech : Thanks for the Info on the 243 BIN. I have tried the CS_243 and the jvvh_243 for Pansat Remote and they both work well for BEV. I had given my approval to a friend two days ago who posts them and the conversion routine with instructions that I wrote originally. Try and look at: http://public.box.net/2500_full_kit |
Post Number: 7670 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 05:55 pm: |
By the way, the 244 file for the real Pansat 2700 is out now. x-87bl_080126_b75_244_api.zip This file can be downloaded from http://www.future-fta.info It is only good for BEV and for real Pansat 2700 - not suitable for clones and converted receivers. |
Post Number: 5 Registered: Jan-08
| Posted on Saturday, January 26, 2008 - 06:03 pm: |
Nalin see u around my friend ! It's time for me to jump back to my hole (-_-) |
