Thread: DiSeEqC Swith |
Bronze Member Username: Ennio
Post Number: 16 Registered: Sep-07
| Posted on Saturday, January 26, 2008 - 09:12 am: |
Is a deferens in quality from one switch to another?? |
Silver Member Username: Lol
Post Number: 278 Registered: Sep-06
| Posted on Saturday, January 26, 2008 - 09:14 am: |
yes some are worth 99 cents like the one that came with your box These are a Good switch -- emp-centauri |
Post Number: 17 Registered: Sep-07
| Posted on Saturday, January 26, 2008 - 10:29 am: |
Thank Paul But :What a good switch give you compare to a chip switch??for the extra $$? Sorry i'm very green at this!! |
Gold Member Username: Nydas
Post Number: 7636 Registered: Jun-06
| Posted on Saturday, January 26, 2008 - 11:52 am: |
DisEqC switches come as 2 to 1 and 4 to 1. Price range $1 to $10. However, there are many other switches such as SW21, DP34, DP44, etc which function for specific needs. After 18 months on the roof (where it should not have been placed in the open), a friend had reason to change it, only to find that the cable had come loose and the switch was OK. That was a $5 switch with Eaglestart label on it. |
Post Number: 19 Registered: Sep-07
| Posted on Saturday, January 26, 2008 - 11:56 am: |
But SW21 switches are good for FTA ?? |
Post Number: 20 Registered: Sep-07
| Posted on Saturday, January 26, 2008 - 12:10 pm: |
A friend of my ware play with his dish and programming nimiq 1 and 2 but we got same channel for each satellite all double what we did wrong?? |
Silver Member Username: Espn3
Post Number: 223 Registered: Aug-06
| Posted on Saturday, January 26, 2008 - 12:18 pm: |
SAR411F made by Spaun is a VERY GOOD switch. It's expensive also: $47.95. Find it on Google. |
Silver Member Username: Asifali418
Lodi,
Ca
Usa
Post Number: 128 Registered: May-06
| Posted on Saturday, January 26, 2008 - 03:13 pm: |
where i found disqec switch i buy from ebay its not work for me i buy it on $8 doller.i return it but they say nothing to me for refund plz tell me where i buy it thnkas |
Silver Member Username: One_eye_jack
Post Number: 283 Registered: Nov-07
| Posted on Saturday, January 26, 2008 - 05:37 pm: |
usa try here.....http://www.nysretail.com/index.php?main_page=product_info&products_id=1&zenid=61 a23414a40a84e6ae9c26722d3f01b0 |
