Home > Message Board > Home Video > Satellite TV > Archive through January 26, 2008 > Box Problem with Coolset 6000
Author Thread: Box Problem with Coolset 6000
Username: Shehzadkamal
Scarborough, Ontario
Post Number: 30
For 2 weeks I am trying new bin to install but my receiver doesnt detect the hardware every time I click the start button on the loader to install software it says please connect your receiver and then press the start button.
Now I tried sevral different ways to install like turing off the box from back and click the start button on the loader while the box is in the standby mode or booting stage and LED shows Night Rider light.
I did a factory reset and then tried loading the bin but it dosnt work....even I am trying to load the factory flash file...it doesnt accept it niether in standby mode nor in the normal mode.
I just bought this reciver couple of months before now I dont know where to go ? Brobably Nylin Nydas could solve this broblem. Banasonic Bebsi ..Abartment.
Username: Kirankumar
Kenya
Post Number: 1109
Shehzad,
you are probably using the wrong cable,
you need a null modem cable.let me know what kind of cable you are using?
Username: Saqeeb9000
Post Number: 1783
i am not sure... isn;t that rec comes with usb slot.. i know 6100 does.
Kenya
Post Number: 1111
Sada,
not 6000 but 6100 onwards does
Post Number: 1784
problem with cable or loader...
try to go to download latest version of csat loader i think its 2.4 and check the cable..
as african said.. there is diff b.w null and other cable..
Kenya
Post Number: 1112
this guy posts a question and then doesn't respond
Post Number: 32
Ok African ....thankyou for yourresponse...beforeI read your reply I kept downloading the bin and the last time changed the cable and I got succeeded ..but I wonder I have been using the previuos cable for a quit long time with quite a number of STB's for my self and my freinds ...I dont know why this cable stopped working now..so I had to lend a cable from my freind.
But I still dont know whats gonna happen next time because I am having this problem from a month having a tough time time laoding the bin.
Post Number: 1788
it worked now...good to hear that..
just changed the cable won't happen again..
and have you heard of
www.d*esifta.co.nr (for downloading bins etc)..
great website by great people...
Home > Message Board > Home Video > Satellite TV > Archive through January 26, 2008 > Box Problem with Coolset 6000 [ « Previous ] [ Next » ]
