Thread: FTA- VIEWSAT/PANSAT |
Silver Member Username: Oleg1474
Florida
Usa
Post Number: 879 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 10:30 pm: |
Well, the Providers aren't wasting any time and are keeping Coders busy, and they barely have time to work on the EMU solution. Map57 is back with a vengance and with a new timing algorithm once again. Coders are using some pretty fancy tools to find the answer to these timing cycles and I'm sure they will find it, because if you don't know what is going on, how are you supposed to write a way around it? Please everyone just be patient. You all know by now they do their best for us, and are determined NOT to let providers win the battle. We have plenty of channels left out there, so enjoy what you have and give these poor guys a chance to work. We'll know more in awhile and will get the info out there. Stay tuned right here to this GREAT site. Thanks!! All PPVs, Adults Premiums, and International channels on DN are down at the moment Now... We have some new news from friends on the inside... I really can't say all of what I know, but the map EMU is down to just a few routines left. It needs some streamlining and cleaning up, but it IS delivering control words accurately right now. There's a map command and a few other little routines to finish, but they are close. I'd say around February 1st, providers may indeed have a tough time bringing us ALL down for awhile. We CAN tell you this, though. Providers are pulling out all stops. They are doing things that the card was never intended to do in an effort to squash FTA. Coders really don't seem too worried, though, so neither should you. We may have a bit of a bumpy ride this month, but soon the tide will turn. Everybody just please remain calm, and check here for the latest updates and be patient and wait! Have the Coders ever let us down yet? We have seen many, many worse situations than this!!Oleg PHD. |
Florida
Usa
Post Number: 880 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 10:35 pm: |
New Bin comming soon everybody just please remain calm, and check here for the latest updates and be patient and wait! |
Florida
Usa
Post Number: 881 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 10:37 pm: |
Good BIN test pass DBPSW-080125 P |
Silver Member Username: Jayson
Post Number: 101 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 10:39 pm: |
hey oleg........what about euro /ecm nagra 3 whatever the heck you called it?????? |
Bronze Member Username: Hotsex
Post Number: 63 Registered: Nov-07
| Posted on Thursday, January 24, 2008 - 10:40 pm: |
DN has won this round...! No more Pirates...No more Jack Sparrows...JA, JA, JA,...No more FTA... |
Post Number: 102 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 10:43 pm: |
eladio.......pansat sucks........and you suck as well...... |
Florida
Usa
Post Number: 883 Registered: Aug-06
SOON SOON SOON !!! |
Bronze Member Username: Sindhiguy
Post Number: 17 Registered: Dec-07
| Posted on Thursday, January 24, 2008 - 10:46 pm: |
so it should be here by tomm ? |
Florida
Usa
Post Number: 884 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 10:47 pm: |
NEW BIN DBPSW-080125P THANKS FOR OLEG PHD. |
Florida
Usa
Post Number: 886 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 10:58 pm: |
At 7:45 EST time in Northern Ontario 3EV went down. I am running 090507U bin and been working fine. I was in the middle of doing fresh scan on N82 and just finished and went to see if I had locals and all was down, I thought what are the chances it was hit while doing the scan, went to sister site and sure enough splash screen says both 3EV and DN are blacked out. Waited 15 minutes and at 8:00PM 3EV came back up with same 090507 bin. Go figure...... My other Ultra with newest bin is also up on 3EV all channels and DN only locals from MN and WI. |
Florida
Usa
Post Number: 887 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 11:12 pm: |
Changing dishes isn't as easy as it looks... Well, sometimes changing a dish goes smoothly, but not this time, not for me. I was swapping my good old Winegard 76 cm dish with a nice new Fortec 90 cm dish. It's pointed at Galaxy 10R, the satellite with the best English-language content but a relatively weak signal. I thought that this would be easy. First, I put a stake in the ground to mark the exact pointing angle for the old dish arm. Then off went the old dish, and on went the new one. The first surprise was that my 7/16-inch wrench (see my getting started list) was useless; the nuts appeared to be metric. Oh well, whatever they were, an adjustable wrench still worked on them. I lined up the arm, adjusted the elevation and ... nothing. No hint of a signal. I tried the usual minor adjustments left-right and up-down. Still nothing. I tried wider adjustments. Still nothing. It was time to get back to basics. When I was first installing my Ku-band dish, a cheap little signal finder (like the one pictured) saved me. More on that in future blog entries. Anyway, I dug it out and, because it won't work with the universal LNBF mounted there, I dusted off my old original standard LNBF. And I do mean "dusted off"; it had been sitting outside on a workbench shelf for over a year. It looks just like this one, a DMSI ASC321. Using one of these little signal finders is as much art as science. You turn the knob until the needle on the meter moves to somewhere in the middle, as the device squeals. Then when you move the dish closer to a strong satellite, the squeal gets louder and the needle moves to higher numbers. Adjust the knob to move the needle back to the middle with this stronger signal, and repeat. Remember when I said that G10R has a weak signal? That meant that it was easy to find every other nearby satellite. By seeing what channels were visible, I could tell when the dish had strayed to AMC 16 or Galaxy 13. That's how I could tell exactly what elevation setting to use and about where to move it east-west. Once the G10R signal locked in, the last adjustment was the optimal position of the LNBF on the arm. I swapped my sensitive univeral LNBF back in, and everything's better than ever. Lessons learned: Maybe you can't predict direction by the way the dish arm is pointing; the replacement dish's arm was at least half a degree to the right of the old one. Those old standard LNBFs work remarkably well for their low price. And even if you only use it once a year, it's worthwhile to keep a cheap little signal finder around. |
Florida
Usa
Post Number: 889 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 11:16 pm: |
NEW BIN COMMING SOON 080125 THANKS FOR OLEG PHD. |
Silver Member Username: Way2smart
Http://desifta.co.nr/
Post Number: 666 Registered: Oct-06
| Posted on Thursday, January 24, 2008 - 11:21 pm: |
wow u r that same oleg????? Or u changed ????? Cuz all u use to post was that new bins are out!!!! i dont know are that or not |
Florida
Usa
Post Number: 890 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 11:29 pm: |
Post Number: 668 Registered: Oct-06
| Posted on Thursday, January 24, 2008 - 11:31 pm: |
u better be right for what were payin yaa |
Florida
Usa
Post Number: 891 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 11:33 pm: |
WWW.THETOTALFTA.COM |
Florida
Usa
Post Number: 892 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 11:37 pm: |
Charlie Outtage... Stay Tuned This page will include files at busy times, Please check this page for all updates. Thanks FOR OLEG PHD. |
Post Number: 670 Registered: Oct-06
| Posted on Thursday, January 24, 2008 - 11:40 pm: |
I hate that site!!!! lol Thanks For THE$MART1 ZEE |
Florida
Usa
Post Number: 893 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 11:44 pm: |
DN just put a new MECM60 in the stream about 10mins ago, as to what it does not sure about. So if you go down in the next day or 2 you know why. They still haven't sent the key down for it yet, so they might wait till tomorrow to activate it. So get ready folks.. Update: Well DN went down this afternoon Wed Jan23rd.. Please dont ask for files when they are out they will be posted.Thanks for OLEG PHD. |
DESIFTA .co.nr
Post Number: 673 Registered: Oct-06
| Posted on Thursday, January 24, 2008 - 11:50 pm: |
OOO oleg give me files u have them all the time please please lol  |
DESIFTA .co.nr
Post Number: 674 Registered: Oct-06
| Posted on Thursday, January 24, 2008 - 11:52 pm: |
ok oleg from ur point of view what receiver will strike first PANSAT OR VIEWSAT its PANSAT All the time Maybe its VIEWSATS Turn |
Florida
Usa
Post Number: 894 Registered: Aug-06
| Posted on Thursday, January 24, 2008 - 11:55 pm: |
Re: Do not flush your files ( had to reload factory pgm) -------------------------------------------------------------------------------- Up and running. Downloaded 071124p-2, tried loading got to 100% and locked up. I hit cancel, I then turned off the receiver. Started up loader 2 again and loaded the factory bin (050521) as normal. It took fine and wated it reset to 0000. Then loaded the nov 24 fix again. The only thing I could think off is there is alot of pgm changes lately and things could have got a little screwed up on the transfer. My 2 cents if someone else has the same problem. Running wide open on be** |
DESIFTA .co.nr
Post Number: 678 Registered: Oct-06
| Posted on Thursday, January 24, 2008 - 11:58 pm: |
ok so u can give the link now!!!! where u got the files from or ur bull$hiting |
Bronze Member Username: Curse429
Post Number: 54 Registered: Aug-07
| Posted on Thursday, January 24, 2008 - 11:59 pm: |
oleg.....what exactly is up & running ? |
DESIFTA .co.nr
Post Number: 679 Registered: Oct-06
| Posted on Friday, January 25, 2008 - 12:00 am: |
its a viewsat i can tell by the date |
Florida
Usa
Post Number: 895 Registered: Aug-06
| Posted on Friday, January 25, 2008 - 09:29 am: |
Charlie Outtage..... Stay Tuned BEV UP Viewsat files coming Friday.... We will attempt to keep this page up to date All information regarding outtages & files will posted here as soon as possible.Thanks for Oleg PHD. |
Florida
Usa
Post Number: 896 Registered: Aug-06
| Posted on Friday, January 25, 2008 - 09:42 am: |
The $mart 1! yes. |
Florida
Usa
Post Number: 897 Registered: Aug-06
| Posted on Friday, January 25, 2008 - 09:51 am: |
Attached Files 20080125_Al7bar_MERCURY2_V0755.z Thanks for Oleg PHD. |
Florida
Usa
Post Number: 898 Registered: Aug-06
| Posted on Friday, January 25, 2008 - 05:40 pm: |
Last Updated: January 25th, 2008 SONICVIEW 1000 SONICVIEW PVR 1000 SONICVIEW 4000 Status:UP Status:Down Status:UP SONICVIEW HD 8000 VIEWSAT 2000 PLATINUM & LITE VIEWSAT 2000 XTREME Status:UP Status:UP Status:UP VIEWSAT 2000 ULTRA VIEWSAT VS PRO VIEWSAT 7000 PVR Status:UP Status:UP Status:UP VIEWSAT 9000 HD |
Silver Member Username: Kll
Post Number: 132 Registered: Jun-06
| Posted on Friday, January 25, 2008 - 05:44 pm: |
OLEG What did you smoke? |
DESIFTA .co.nr
Post Number: 692 Registered: Oct-06
so where are they????? I u really have them then go post them up at Desifta .co.nr |
Bronze Member Username: Desi_munda
Post Number: 59 Registered: Nov-07
| Posted on Friday, January 25, 2008 - 05:54 pm: |
the new bin for pansat 2500/a is out, check on fta-bins |
Bronze Member Username: Survayman12
Post Number: 15 Registered: Jun-06
| Posted on Friday, January 25, 2008 - 06:49 pm: |
BEV only; NO DN bins yet. Oleg is a GOOF PHD |
Bronze Member Username: Mustana70
Wenonah,
New Jersey
Post Number: 12 Registered: Jan-08
| Posted on Friday, January 25, 2008 - 07:16 pm: |
still no news on vs. Just keep waiting and waiting and waiting and... |
Silver Member Username: Xtrawest
BC
Post Number: 123 Registered: Nov-05
| Posted on Friday, January 25, 2008 - 07:31 pm: |
its its time to buy NFusion Nova.. in't..?? |
BC
Post Number: 124 Registered: Nov-05
| Posted on Friday, January 25, 2008 - 07:46 pm: |
Welcome: xtrawest - Jan 25 - DN still down most receivers - Bev scrambled on some receivers now too - Bev fixes released: CNX, Pansat, Sonicview |
Silver Member Username: Dakangofkrunk16
Post Number: 998 Registered: May-07
| Posted on Friday, January 25, 2008 - 09:41 pm: |
It says new vs bins coming out Friday, and today is friday.. prolly gonna come out at like 11:59 pm |
Florida
Usa
Post Number: 899 Registered: Aug-06
| Posted on Friday, January 25, 2008 - 10:27 pm: |
Nagravision 3 keys Polsat ID IDEEA key Keys are not yet available IDEEA key Keys are not yet available TV Cabo ID 56 44 IDEEA key Keys are not yet available IDEEA key As chaves não estão ainda disponíveis D+ ID IDEEA key Keys are not yet available IDEEA key Las llaves no están todavía disponibles |
Florida
Usa
Post Number: 900 Registered: Aug-06
| Posted on Friday, January 25, 2008 - 10:30 pm: |
D+ ID 41 01 IDEEA key 86 D+ switched all to Nagra 3 IDEEA key 96 http://www.rdi-files.com/nagra3.php RSA key (128 chars) D91FB482F54C4535621D845F7EC4AB4DC9309DED26B54030848EB63968977529 FE8FF18613276171E57BDA8A47AC993703CCE2A1CB071998ECCB327EF63CCEA7 nagra-3 comming soon ...Thanks for Oleg PHD. |
Bronze Member Username: Zeez
San Mateo,
CA
Post Number: 14 Registered: Dec-07
| Posted on Friday, January 25, 2008 - 10:45 pm: |
Anyone knows if this file works on DN too? http://www.ftatalk.com/showthread.php?t=119415 |
Florida
Usa
Post Number: 903 Registered: Aug-06
| Posted on Saturday, January 26, 2008 - 12:07 am: |
http://www.ftaclub.net/forum/profile.php?mode=activate&u=97372&act_key=64f7e777b a973d |
San Mateo,
CA
Post Number: 15 Registered: Dec-07
| Posted on Saturday, January 26, 2008 - 03:31 am: |
Hi Oleg, your link goes to a German site, anything you wanted us to know? |
