Home > Message Board > Home Video > HDTV Reception > Viewing HDTV
Author Thread: Viewing HDTV
Username: Ralphs
I have Verizon FiOS service. At present have 3 TVs with 3 boxes. Am not interested in PPV or any of the bells & whistels that come with the box. Question: Will a newly installed HDTV receive HD signal without the box? Will I be able to use the Verizon channels to view programs.
Relevant Product Info
Username: Tapeman
New York City in-HD, NY
Post Number: 2196
Yo can get all locals HD and any HD in clear (non-encrypted pgms)
Plug cable directly to TV tuner and start scanning
Yo can return one box and share one box This is how to:
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1063352#POST1063352
Username: Ralphs
Am planing to buy a LCD HDTV. The seller recommends purchasing an additional bundle consisting of 2 HDMI cables, 2 audio cables, 3 component cables and a cleaning kit. All for $90.00. Is this a necessary purchase for simply viewing HD and SD channels? Thanks.
Username: Tapeman
Post Number: 2231
I wouldn't
Check e-bay
Prices a lot cheaper
Username: Ralphs
In reference to the above. Thanks for the info. I guess my real question should have been--Is that bundle necessary to hook-up the new TV, or is it used for accessories? Since this will be a wall mounted installation, can I simply connect to the existing Verizon cable?
Username: Tapeman
Post Number: 2245
Verizon is responsible to get yo up and runing for new installation (1-TV)only this means providing yo all cables required for the service for up to 1-TV bu simply ask verizon
For your seller $90 is a lot
Compare prices at e-bay and maybe make your choice
Do yo need the wires?
Yes won't work without
Username: Ralphs
It is my understanding, in order to receive an HD signal on a new HDTV, you must have an HD set top box. If this is true, is one obligated to rent a box from the cable company, or can it be purchased from an independent supplier (bearing in mind I'm not interested in PPV) to save the monthly rental fee?
Username: Tapeman
Post Number: 2324
No
As long as yo pay for basic cable Yo should be able to get ABC,CBS,NBC,Fox,WB,PBS and even few more all in HD
But not TBS,TNT,USA,CNN,ESPN,MTV these require service box
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > HDTV Reception > Viewing HDTV [ « Previous ] [ Next » ]
