Thread: My TV has 1 DVI, no HDMI, how do I... |
Bronze Member Username: Kevinrob
Post Number: 18 Registered: Jan-08
| Posted on Saturday, January 19, 2008 - 06:17 pm: |
My HDTV is a bit older than most, 4 years approximately. It has 1 DVI connection, no HDMI connections. The problem is do I hook up the DirecTv HR21 receiver or the progressive scan DVD player to DVI? The other device would be connected via Component cables. The other option is to get a multi-switch DVI cable that allows you to connect 3 DVI devices to the TV, but I then have the problem of converting the HMDI connections to DVI. Any suggestions would be appreciated. |
Silver Member Username: Tvshopper
Post Number: 196 Registered: Mar-06
| Posted on Monday, January 21, 2008 - 10:42 am: |
I don't think you lose or gain anything by hooking up the HR21 via component cables. I have my HR20 hooked up with both HDMI and component and cannot tell the difference. So, I would hook up the DVD player via the DVI. |
Post Number: 24 Registered: Jan-08
| Posted on Monday, January 21, 2008 - 06:25 pm: |
Cool, thanks for the info tvshopper. I guess I will give it a try and see how it looks. The bigger issue I'm finding is that most of the upscale DVD players/recorders say they only upscale via HDMI so I may have to go that route. |
New member Username: Sprintmgr
SLC,
UT
Post Number: 1 Registered: Feb-08
| Posted on Friday, February 01, 2008 - 01:18 pm: |
I had the same problem on my last TV, and I found an inexpensive DVI to HDMI adapter. You lose sound on the DVI side, but most devices will allow you to run audio separately. (you would if using component anyway) I found a monster brand adapter at Radio Shack for $30. Once you have HDMI, there are a number of solutions that allow switching/combining devices, including receivers with HDMI ins and a separate HDMI switching box. Good luck, and I hope this helps. |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 2096 Registered: Feb-04
| Posted on Saturday, February 02, 2008 - 11:46 am: |
As tvshopper says component works very well in most situations. However, I just recently started using an HDMI cable hooked up to a DVI adaptor on my HD DVD player. My Monoprice $3.63 (+ s&h) HDMI®DVI adaptor works very well. http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10419&cs_id=1041902 &p_id=2029&seq=1&format=2 |
