Thread: Component cables or hdmi? |
Silver Member Username: Mrsq
California
Post Number: 153 Registered: May-06
| Posted on Saturday, January 19, 2008 - 04:44 am: |
i go component, cheaper and has better audio |
Relevant Product Info
Silver Member Username: Hd_fanatic
Boise,
ID
Post Number: 199 Registered: May-05
| Posted on Saturday, January 19, 2008 - 02:03 pm: |
Component cables only transfer video, not audio so they do not have better audio. If what you are trying to say is that by running component for video and toslink or coaxial for audio, then maybe. If your TV has an HDMI input, I would use it. The video transfer through HDMI is pure digital as opposed to component which transfers the data in analog form. If you do not like the audio from your HDMI, then just run your HDMI to directly to the TV and toslink (optical) or coaxial to your receiver. I believe that most people on this forum would agree that HDMI is clearly the better choice. Its a no brainer. As for your comment on pricing, go to monoprice.com. Awesome cables for a fraction of the cost of high-end brands. |
Bronze Member Username: Kevinrob
Post Number: 21 Registered: Jan-08
| Posted on Saturday, January 19, 2008 - 09:51 pm: |
Do Component and HDMI have the same HD capability? 720p and 1080i? |
Gold Member Username: Samijubal
Post Number: 3716 Registered: Jul-04
| Posted on Saturday, January 19, 2008 - 11:22 pm: |
Both can do 720p and 1080i. Both have the capability to do 1080p, but not many products will do 1080p over unprotected analog component connections. |
