Home > Message Board > Home Video > TV Basics > Archive through June 21, 2008 > Ant-in on Samsung HLN567W
Author Thread: Ant-in on Samsung HLN567W
Username: Kevinrob
I have a rooftop antenna connected through my DirecTv H10-250 so I can watch my local channels in HD. When I connect the antenna wire directly to my Samsung DLP tv through the Ant-A in, only a couple of channels come in and they are very fuzzy. These same channels are crystal clear and in HD through my Satelite receiver.
Can I connect the antenna directly to my TV to receive my local channels in HD?
Username: Imjross
NJ
Post Number: 43
Yes, Then autoprogram to scan for AIR cannels..jr
Username: Kevinrob
Post Number: 7
Thanks J, I will give it another try tonight. I tried to use the Fine tune on the AIR channels, but it didn't work well. This is the option that allows you to fine tune with +/- to get the best picture. Will let you know how it goes...
Username: Kevinrob
Post Number: 8
Hmmm, couldn't get it to work. Do I need a DVD player with a tuner between the Antenna and the TV? Would this help the signal?
Home > Message Board > Home Video > TV Basics > Archive through June 21, 2008 > Ant-in on Samsung HLN567W [ « Previous ] [ Next » ]
