Home > Message Board > Home Video > VCR > Digital cable box run through VCR
Author Thread: Digital cable box run through VCR
Username: Vakil
I have just installed digital cable, using a Motorola cable box. I routed the coaxial cable through the vcr, so I can record shows if I want to. Now, I can't watch shows when the VCR is set to video. I have to set it to TV (essentially turning the VCR off). When I try to record, all that I get is a blue screen recorded on the tape. I have been able to do this before with digital cable.
Username: Ieee488
Post Number: 23
So, you have coaxial cable routed from the wall to your VCR bypassing the cable box?
If you do this, then you won't be able to get the digital cable channels. You do realize this ????
Username: Samijubal
Post Number: 3728
Split the incominng cable to the box and VCR, then connect RCA cables from the box to the VCR and VCR to TV. When you want to record analog channels, use the VCR tuner, when you want to record digital channels, use the box and set the VCR to line.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > VCR > Digital cable box run through VCR [ « Previous ] [ Next » ]
