Thread: Dubbing VHS to DVD via DMR-ES40V |
New member Username: Chris0516
Santa Fe,
New Mexico
Post Number: 1 Registered: Jan-08
| Posted on Sunday, January 06, 2008 - 10:40 am: |
I have the VHS/DVD combo machine mentioned in the Subject line. When I dub a VHS tape to DVD, it doesn't seem to consistently record audio while, video is fine. I have read here, in reference to other combo machines on this website, that a separate VCR would need to be hooked up. Would that also be the case with what I have? |
Relevant Product Info
Gold Member Username: Samijubal
Post Number: 3699 Registered: Jul-04
| Posted on Sunday, January 06, 2008 - 11:08 am: |
A seperate VCR is needed when the tapes are retail. You've either got a defective recorder or bad tapes. Look at one of the tapes in question and see if the bottom edge of the tape is crinkled. |
Santa Fe,
New Mexico
Post Number: 2 Registered: Jan-08
| Posted on Sunday, January 06, 2008 - 12:26 pm: |
I think the machine is defective because, after I read your reply, I went ahead and, erased a DVD-R/W and, started dubbing the same VHS tape again. In the beginning I was getting audio from the tape but, then the dubbing continued, without audio. |
Post Number: 3700 Registered: Jul-04
| Posted on Sunday, January 06, 2008 - 04:23 pm: |
Look at the tape and see if the bottom edge is crinkled. |
