Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > PANSAT 2700A urgent help necessary
Author Thread: PANSAT 2700A urgent help necessary
Username: Malben
La Paz, Baja Califor...
Mexico
AFTER UPLOADING NEW BOOT FILE AND BIN WHEN ENTERING parental control i am no longer able to enter the keys manually the only thing i get is the old pin and the new pin info it no longer sends me to where you enter your new keys can anyone help me or tell me what i havbe to modify
thank you
Username: Kukkudo
Post Number: 57
go down to second pin and hit 0000
Username: Dude123
Post Number: 1770
or to skip that step just press 8282 on your remote like you would normally change you channel and it will take you in parental control menu, then go to nagravision2 to enter keys manually
Username: Haider5518
Post Number: 13
hi
one or av
i have labtop what kind of kabel do i have to us for me to download a new pin to my 2700A
Username: Malben
Mexico
itried the two options but it was not succeful now what can i try or do to put the keys in my pansat
Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > PANSAT 2700A urgent help necessary [ « Previous ] [ Next » ]
