Thread: 2500A remote on convert 2700 |
New member Username: Hangon
Post Number: 8 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 10:25 pm: |
Hard boots when I turn off the receiver. Sometimes no signal, have to turn off/on the switch in the back to reboot. Sometimes I have to re-boot it a few times? CS_235t file. Any updates? |
Silver Member Username: Jagr1234
Post Number: 149 Registered: Nov-07
| Posted on Saturday, January 05, 2008 - 10:33 pm: |
i have also been having issues with 235, both JVVH and CS, it works but tries to roll keys when there is no update, then it rolls forever. i usually reset default keys when that happens. otherwise it would roll for 20min if I let it. also have the scrambled channel when changing channels. as reported it goes away after 20-30 secs. |
Silver Member Username: Kirankumar
Kenya
Post Number: 710 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 10:48 pm: |
Guys, you all know that ecoustics is not an fta site,we just try and help each other and fool around more then we learn. AV and the The One have have started a new site crazyfta.com we would like you guys to join that site,because you will be able to download files.bins and how to materials. also the site is going to be monitored so you will get the full help you need without spammers killing a thread. we promise to help you and keep you updated with the latest files very fast. most of all the site is free if you register right now.site is up and running,see you guys there |
Post Number: 9 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 11:13 pm: |
African, already joined. Please post on pansat threads. Sled King |
