Thread: Straight or null |
Bronze Member Username: Rbhoop
Post Number: 28 Registered: Jun-06
| Posted on Saturday, January 05, 2008 - 06:06 pm: |
Sorry for all the stupid questions guys but i have been reading about cables and still not sure if iam using the right cable for my flu.it has female connectors on both ends.when i try to load a bin it seems to download ok then it says BURN then ok but the lights are still flashing when its completed.If i was using the wrong cable would it still let me see progress on the loader Thanks all for your help |
Silver Member Username: Nikk
Post Number: 495 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 06:17 pm: |
If the indicator shows progress while downloading and it says BURN, then OK, then you are using the right cable... For FLU you need to download bin CS-235T...you must unzip the file in order to download it, the file must have the extension ".bin".... Another thing is that maybe you have not converted you FLU to 2700 clon yet....check if when you turn on the receiver the display shows the legend b-75 twice...if not then you must convert your receiver first in order to download the latest bin.... If that is the case then go to ftabins.net to the FLU files section, there you will find instructions on how to convert it... |
Gold Member Username: Saqeeb9000
Post Number: 1383 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 06:18 pm: |
cables are ok... |
Gold Member Username: Rtap
FL
Post Number: 1571 Registered: Jan-07
| Posted on Saturday, January 05, 2008 - 07:11 pm: |
A Ariza Ultra 400 - Null Ariza Ultra 500 - Null Ariza 700 - Null Ariza 750 - Null Ariza Extreme - Null Astrovox 2600 - Straight DB9 B Blackbird and ALL Blackbird CLONES - Null BlueJay2 - Null Buzz S2010F - Null Buzz S2010F Plus - Null Buzz S2020F - Null C Captain 7000 Premium - Null Captian 8000HD - Null Captain 9000DVR - Null CaptiveWorks 100R PVR Unit - Null & USB CaptiveWorks 500S - Null CaptiveWorks 600S - Null CaptiveWorks 600 Premium - Null CaptiveWorks 1000 - Null & USB & ETHERNET CaptiveWorks 3000HD - USB & ETHERNET Conaxsat CNX-V1 - Null & USB Conaxsat Duo - Null & USB Conaxsat Trio - Null & USB Coolsats 4000 Plus - Null Coolsats 4000 Pro - Straight DB9 Coolsats5000 - Straight DB9 Coolsats 6000 - Straight DB9 Coolsats 7000 PVR - Straight DB9 & USB Coolsats 8000HD - Null Coolsats 8100HD - Null Cooltec - Straight DB9 Coship (All) - Null D DGStation Mutant 200S - Null DGStation Relook 400S - Null DGStation Relook 300SV - Null Digiwave 5900C - Null Digiwave 6800 - Null Digiwave 7000 - Null Digiwave 7200S - Null Digiwave Diamond - Straight DB9 Dreambox (All) - Null E Eagle Star 2500A - Straight DB9 Ebox Mimic (Viewsat Clone) - Null Extremeview Magnum XV3300 - Null F Fortec 5000v2 - Null Fortec 5100 Diamond - Straight DB9 Fortec 5100 Plus - Straight DB9 Fortec 5100 Plus+ - Straight DB9 Fortec 5100 Ultra - Straight DB9 Fortec 5400 NA - Null Fortec 5400 - Null Fortec 5600 Plus - Straight DB9 Fortec 5600 Ultra - Straight DB9 Fortec 5600v2 - Null Fortec ALPHA - Null Fortec BETA - Null Fortec LIFETIME - Straight DB9 Fortec Lifetime Classic NA - Null Fortec Lifetime Classic - Null Fortec Lifetime Diamond - Straight DB9 Fortec Lifetime ULTRA - Straight DB9 Fortec Lifetime Ultra Diamond - Straight DB9 Fortec MAGIC - Straight DB9 Fortec MERCURY II - Null Fortec Platinum NA - Null Fortec PLATINUM - Null Fortec Ultimate - Straight DB9 L Lava 2600 - Null Lava 3200 - Straight DB9 Lava 3500 - Null M Max 2500 - Null Megasat (All) - Straight DB9 Microroyal (All) - Null Mvidea FS 4000 - Null N Neosat Lite - Straight DB9 Neosat Lite Premier - Straight DB9 Neosat iPro1000 - Null & ETHERNET Neosat iPro2000 - Null Neusat SP6000 - Null & USB Neusat SP6000 Premium - Null & USB Neusat 9000HD - Null & USB NFusion Nova - Null & ETHERNET O Orasat V3 - Null Orasat V5 - Null P Pansat 200A - Null Pansat 250SM - Null Pansat 300A - Null Pansat 330A - Null Pansat 500 CI - Null Pansat 700H - Null Pansat 1500a - Straight DB9 Pansat 2000V - Null Pansat 2300a - Straight DB9 Pansat 2500a and ALL 2500 CLONES - Straight DB9 Pansat 2700A/E and MOST 2700 CLONES - Null Pansat 3500S - Null Pansat 3500SD - Null & SD CARD Pansat 5000HC - Null & USB Pansat 6000HXC PVR - Null & USB Pansat 9000HD - Null & USB Pantec/Multistar Max (All) - Null Pantec/Multistar MS (All except MS1000) - Straight DB9 Pantec MX/Ultra - Straight DB9 R Rex1 - Null S SatCruiser - Null Satopia ST1100-UT - Null SatPros DSR500 - Null Silver Bullet/ST 1000 - Null Silver Bullet/ST 2000 - Null Skytech 2700A - Null Skyview 500 - Straight DB9 Skyview RX600 - Null SkyView Plus SV-P1000 - Null Smartwave 2500A-N2 - Straight DB9 Smartwave 2700A-N2 - Straight DB9 Sonicview SV-1000 - Null SonicView SV1000 PVR - Null & USB Sonicview SV-4000 - Null & USB SonicView SV-8000HD - Null & USB Sonicsat Koolsat - Null Spacestar DVB500 - Null Stealth 2000a - Null T Technosat 1010 Plus - Null Techsat - Null Traxis DBS 1500 - Straight DB9 Traxis DBS 2500 - Straight DB9 Traxis DBS 3500 - Straight DB9 Traxis DBS 4500 - Straight DB9 Traxis DBS 4550 - Straight DB9 Trimax T100 - Straight DB9 U Ultrastar 5000 - Null V Viewsat VS2000 Lite - Null Viewsat VS2000 Platinum - Null Viewsat VS2000 Extreme - Null Viewsat VS2000 Ultra - Null & USB Viewsat VSPro - Null & USB Visionsat IV200 - Straight DB9 Visionsat IV300 - Straight DB9 Vortex 2700 - Null Vortex 3500 - Null Vortex 7700 - Straight DB9 X Xrica X-5 - Null |
