Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > Loading file onto Pansat Receiver
Author Thread: Loading file onto Pansat Receiver
Username: Afaizi
Post Number: 46
Hey I had a question whether I can use the same wire that I use to load a file to my Fortec Lifetime Ultra to my Pansat 2700 or do I need a different wire for the Pansat receiver. Any feedback would be greatly appreciated. Thanks
Username: Kirankumar
Kenya
Post Number: 692
afaizi,
try using it,if it does not work then it is not going to do any harm
if it doesn't work post here so we can help.good luck
Username: Tale
Post Number: 120
Pansat 2700 uses null twisted serial cable ...so it's different !
Username: Jagr1234
Post Number: 146
i use same serial cable for both flu and 2500
never any issues
Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > Loading file onto Pansat Receiver [ « Previous ] [ Next » ]
