Thread: Ariza 700 autoroll option |
Bronze Member Username: Chichos26
Post Number: 55 Registered: Dec-07
| Posted on Saturday, January 05, 2008 - 04:15 pm: |
how i can go in autoroll option in Ariza 700 when i hit menu then parental control under old pin enter 2004 and is only for change the old pin |
Gold Member Username: Saqeeb9000
Post Number: 1364 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 04:19 pm: |
i don't have ariza.. but did you check it on setting.. |
Post Number: 57 Registered: Dec-07
| Posted on Saturday, January 05, 2008 - 04:21 pm: |
is not there |
New member Username: Aysa
Toronto,
On
Post Number: 1 Registered: Jan-08
| Posted on Saturday, January 05, 2008 - 04:59 pm: |
you have to press 'i 2004' to get in does anyone know which file is for the ariza 750 from mingo jan 2 2008 fix? i appreciate the help |
Silver Member Username: Ustaad_hc
Post Number: 532 Registered: Oct-06
| Posted on Saturday, January 05, 2008 - 08:53 pm: |
bin start with AA-2 |
Post Number: 64 Registered: Dec-07
| Posted on Saturday, January 05, 2008 - 09:06 pm: |
AHHH OK THANS SAFA (( I )) = INFO KEY OK OK OK ARIZA 750 aa-2_h20080102_309e_MINGO.bin |
Post Number: 65 Registered: Dec-07
| Posted on Saturday, January 05, 2008 - 09:07 pm: |
AFTER LOADED THE IN SET DEFAUT KEY A AUTOROLL ON |
