Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > Viewsat down?
Author Thread: Viewsat down?
Username: Thadragun
Kingston, Ontario
Post Number: 52
I can never tell if the satellite is down now... Since the last couple fixes froze all the time.
I have a ViewSat Pro and the last couple days it's been working fine. Would freeze unless the channel was changed, then it would unfreeze. In the middle of a movie it froze and now says autoroll.
Is Bev down again? It's been stuck on autoroll for over 30min.
thanks
Username: Lol
Post Number: 181
move up a channel then back should AR again
Username: Thadragun
Kingston, Ontario
Post Number: 53
That didn't work. I ended up doing a hard boot by flicking the switch on the back and it worked again..
thx
Username: Shn
Post Number: 21
i'm new at this and a little lost. almost all my channels were taken out and i dont know what to do. i heard about a bin or file needing to be download onto my viewsat. where can i find the newest bin to download for the viewsat xtreme? do i have to pay for the bin? Pleeease help me!!!!!! thanks bye
Username: Lol
Post Number: 182
latest extreme file
http://www.evilshare.com/8c1e93c0-0d05-102b-8573-00a0c993e9d6
you'll need the loader believe u can find it at www.viewsatusa.com in file section
Username: Saqeeb9000
Post Number: 1367
i just saw a brest there..that girl was hot..
Username: Curse429
Post Number: 44
loaded latest bin for vw extreme.....DN works but BEV does not.....is bev down ?
Username: Jojogun
Fairfield, CA
United States
Post Number: 355
mike........on dssworld the mod has advised against using bev on the new file. he said that it might temporary lock up your receiver. he also said that the coders said that new bins are in the works to fix the problem. I had to go in my son's room and delete all the bev channels before he started using them.
Username: Lol
Post Number: 183
jojogun the new file you say is in the works was released this morning for Extremes and Plats
Username: Pansir
The new Bin works well on my VS2000/Platinum and Xtreme for BTV
Username: Shn
Post Number: 23
thanks, paul
Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > Viewsat down? [ « Previous ] [ Next » ]
