Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > How to scan particular TP
Author Thread: How to scan particular TP
Username: Jppatelahd
Post Number: 44
i didn't have some channels on 61.5 echostar 3 and i have Captive works 600S premium and i have only one dish..
Post Number: 45
where r u african, nalin and all expert?
help please??
Post Number: 46
because i didn't have zeetv, zee cinema, b4u movies, and some other channels. i search on somewhere that those are on TP 27 on 61.5 w. so may be i am thinking that i have to scan this tp again. i don't want to scan whole satellite because what i am scare it will create any other problem..
Post Number: 47
african i waiting for u since one hour?
Username: Dimwitt
Post Number: 348
menu , installation , antenna settings , select the TP you want to scan , at the bottom of the screen there will be a color next to the word transponder .
press that colored button on remote to start TP scan
with the 600S its the yellow button--might be different on the premium
Post Number: 48
actually i didn't getting zeetv, zeecinema , b4umovies etc. i want help man??
please?????????
Username: Kirankumar
Kenya
Post Number: 665
Jignesh,
it will be better if you scan all channels again,it will be easier for you
Post Number: 50
if it will damage more than
Kenya
Post Number: 667
no it won't
Kenya
Post Number: 668
scanning channels will not harm your box
Kenya
Post Number: 669
Jignesh,
You do have 61.5 bird right? or are you pinted somewhere else
Post Number: 52
ya i pointed at 61.5 bird but when i go to antenna settings some tp saws quality but some not and tp of zeetv, zeecinema etc is 12297 which saws me 0 quality. i don't know why?
any help please????
Kenya
Post Number: 675
Jignesh,
please list all your settings here
Post Number: 53
Satellite name : 57.echostar 3 (61.5 w)
Transponder : 12603/v/20000/5/6
Lbn freq : 11250
Lnb type : normal
22khz : oof
Diseqc number : none
Legacy SW : off
Motorised system : none
Kenya
Post Number: 677
Jignesh,
how many dish you have and how many lnb and what kind of switch?
how many birds are you trying to get and which ones
Post Number: 54
i have only one dish, only one lnb and its very simple.. i trying only one bird yar?
i clarify all this above.. thats ok..
help please
Kenya
Post Number: 678
try and see if you can get these settings
61.5 echostar 3 rainbow
transponder 12326
lnb single
leave the rest as it is
and do a scan.
also has you system ever worked?if not who installed your dish?
Post Number: 55
ya before 3 days all channel works in my receiver ?
i don't know why this is happening?
one of my friend installed dish!!
i don't think so i will see 61.5 echostar 3 rainbow. how i will get it??
Post Number: 56
also u didn't clearify that transponder whole string means 12326 than what h or v and else
Kenya
Post Number: 679
we need to get Nalin or FTA Tester on this because i don't know how to change the settings on your particular box.
Kenya
Post Number: 680
Jignesh,
can you go to this site and download manual.
it shows how to change settings and find stellite.
http://www.ftabins.net/showthread.php?t=2848.
you will have to register,it is free .the main site is ftabins
Post Number: 57
can u call them for me? please!!!!!!!!!!!
Kenya
Post Number: 681
what?
i hope you are not fooling around with me
Post Number: 58
no man i am serious about this matter?
i mean if u see them on another thread than just let them know that help this guy please??
Username: Saqeeb9000
Post Number: 1357
jignesh.. just do an advance scan... type freq,pol etc.. and u will get the channels..
if it doesn't help... do a blind scan.. it will scan all the freq...
last method it to install a factory bin and reload the new bin again..
if all failed throw your rec and buy nfusion.
Username: Solano2008
Toronto, Ontario
Post Number: 25
i have FLU converted 2700 I am getting most of the english channels but no indian channels what could be the problem. PPV.P*RN are coming help please
Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > How to scan particular TP [ « Previous ] [ Next » ]
