Thread: Help with loader for 2700a ! |
New member Username: Cooljo
Post Number: 10 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 09:00 am: |
someone please confirm that this is the loader i need to use for my pansat2700a Pansat 2700 GTRom Loader v3.35 |
Silver Member Username: Jowhar
Post Number: 152 Registered: Jun-06
| Posted on Saturday, January 05, 2008 - 09:02 am: |
is it clone |
Bronze Member Username: Cooljo
Post Number: 11 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 09:04 am: |
no, i am new at this..but i think it is an original |
Bronze Member Username: Iamdrumming
Post Number: 61 Registered: Aug-06
| Posted on Saturday, January 05, 2008 - 09:10 am: |
Hi Joan, If your 2700a already has b-75 on it, the latest loader is GTRom Loader v27.02 [Pansat2700A - B75].exe People just call it v27.02 |
Post Number: 12 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 09:14 am: |
sorry for this silly question , but how do i find out if my 2700a has a b-75 on it???? |
Post Number: 62 Registered: Aug-06
| Posted on Saturday, January 05, 2008 - 09:17 am: |
No silly questions here As soon as you turn on your 2700a, 'b-75' should scroll across the display a couple times. Then you know your 2700a has 'b-75' on it. B-75 is the update that took place back in March. |
Post Number: 154 Registered: Jun-06
turn off your receiver and on you will find out |
Post Number: 13 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 09:20 am: |
ok..i'll do that |
Post Number: 63 Registered: Aug-06
| Posted on Saturday, January 05, 2008 - 09:21 am: |
Also, since you are new, I really recommend going to the official Pansat site. It is: http://www.future-fta.info The site is down right now, but once it is up, you'll find lots of info there. Don't go to any other website that is usually spammed here. |
Post Number: 14 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 09:24 am: |
hmm..nothing happened,i dont think any update has been done in a year since i have this unit.!! the last time the bin changed,i was too skeptical to do it my self, now with most of the channels gone,i have no option!!! |
Silver Member Username: Dimwitt
Post Number: 346 Registered: Aug-06
| Posted on Saturday, January 05, 2008 - 09:26 am: |
to check boot version either press the menu button and the system info will be in the lower right of screen --boot ver. or reboot receiver by turning off then on with the backswitch --the boot ver. will be displayed on the receiver -looking for b-75 |
Post Number: 15 Registered: Oct-07
ok i will go to the website you recommended... |
Post Number: 16 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 09:29 am: |
ok the system info says x-87BL API:2.92-Eubx BOOT VER:6.2 25 JAN 2007 |
Post Number: 17 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 09:37 am: |
GUYS..TELL ME SOMETHING,ABOUT THE SYSTEM INFO I JUST POSTED...... AM I TOO FAR BEHIND.. |
Post Number: 18 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 09:53 am: |
OK..ONE MORE INFO I ALREADY HAVE A GTROM LOADER V27.01 ON MY COMPUTER,WHICH I DOWNLOADED IN OCT WHEN THE BINS FIRST CHANGED ...CAN I USE THAT?? |
Post Number: 347 Registered: Aug-06
| Posted on Saturday, January 05, 2008 - 09:56 am: |
go here www.pansatusa.com/download.htm read the instructions for 2700 b-75 everything you need to upgrade to b-75 is included in the 2700b-75 software then download the latest bin which can be found at future-fta.info |
Post Number: 19 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 09:58 am: |
THANKS A LOT TOOTER, I WILL DO JUST THAT. |
Silver Member Username: Charjam
Post Number: 286 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 11:35 am: |
i have a 2700a and you need 27.02 loader but there are two of them one says write file and the other says download the one that says write file does not work for me |
Post Number: 20 Registered: Oct-07
| Posted on Saturday, January 05, 2008 - 01:02 pm: |
try downloading it,i did the same. |
