Thread: HELP MIN NEED |
Bronze Member Username: Beenthere
Post Number: 25 Registered: Aug-07
| Posted on Saturday, January 05, 2008 - 01:23 am: |
I DOWNLOADED THE NEW VSX FILE TO MY DESKTOP,WENT THREW LOADER2 HOOKED UP THE WIRE AND IT WONT TRANSFER FROM PC TO STB WHEN I TURN THE RECIEVER OFF AND ON. WHAT AM I DOING WRONG, ANY HELP PLEASE. |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 3230 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 01:29 am: |
first what is your receiver? reboot the host computer then try it again.. Loader2 User Guide “Loader2” can download the firmware from PC to STB. 1. Install “Loader2” to your PC. 2. PLUG OUT YOUR STB FROM OUTLET. 3. Connect “NULL MODEM CABLE” between PC and STB. 4. Run “Loader2” on PC. 5. Run the “Tool->Configuration” menu and select serial port what you use. 6. Press “Open File” button and select the file what you want to download. 7. And then press “PC->STB” button. WHEN ZMODEM WINDOW IS APPEARING, PLUG IN YOUR STB. 8. Then selected file will download from PC to STB. 9. When download is complete, you can see below message. When you see this dialog on PC, STB will start to write flash memory. Please wait until STB automatically reboot.
Post Number: 26 Registered: Aug-07
| Posted on Saturday, January 05, 2008 - 01:34 am: |
sorry, my reciever is a VS exteme and downloaded DBPSW-080104x |
I WILL FIND...
Post Number: 3235 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 01:39 am: |
has this cord been used before? reboot the host computer, try it again...if it fails start over change the com port....if fail try again....change to the next com port.....you can get it |
Post Number: 27 Registered: Aug-07
| Posted on Saturday, January 05, 2008 - 01:48 am: |
yes I used the cord before,reboot host computer meaning re start computer? |
I WILL FIND...
Post Number: 3240 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 01:50 am: |
yes in XP click start, then reboot |
Post Number: 28 Registered: Aug-07
| Posted on Saturday, January 05, 2008 - 01:56 am: |
No luck |
I WILL FIND...
Post Number: 3242 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 01:58 am: |
you tried every com port? |
Post Number: 29 Registered: Aug-07
| Posted on Saturday, January 05, 2008 - 02:07 am: |
yes "frame type 000 000" just keeps blicking |
I WILL FIND...
Post Number: 3246 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 02:16 am: |
cord is bad, serial port on your computer is bad now, something in the computer stoping it from working |
Post Number: 30 Registered: Aug-07
| Posted on Saturday, January 05, 2008 - 02:26 am: |
new cord, weird problem.thanks for your help FTA |
I WILL FIND...
Post Number: 3250 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 03:14 am: |
cool |
