Thread: Can anyone help me ? |
Bronze Member Username: Jerkisland
Post Number: 70 Registered: Mar-07
| Posted on Friday, January 04, 2008 - 11:31 pm: |
I loaded the new bin file and channel file for viewsat extreme, though it said everything succesfully I get no channel displayed on the receiver. I had to do a blind scan to get the channels, can someone tell what might be wrong that I didn't get the channels when I loaded the CHA file along with new bin file? |
Gold Member Username: Saqeeb9000
Post Number: 1344 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:34 pm: |
i think ftatester is tired of this... here is what to do by ftatester.. http://forum.ecoustics.com/bbs/messages/2/428318.html |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 3198 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 11:36 pm: |
sure just like did for you last time... I made a guide for you! Next time do what it say's and in 5 min you will watching tv, eating popcorn enjoying life and not looking at a receiver with no channels
Post Number: 71 Registered: Mar-07
| Posted on Friday, January 04, 2008 - 11:37 pm: |
Sada Bhai, I tried exact same steps but even though Channel file (*cha) is succesfully downloaded, I still don't see the channel list. |
I WILL FIND...
Post Number: 3200 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 11:39 pm: |
you missed something.....cheak the cha file useing osdedit |
Post Number: 1347 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:40 pm: |
are u getting signal right... did u check your port setting every thing is correct? |
Post Number: 72 Registered: Mar-07
| Posted on Friday, January 04, 2008 - 11:42 pm: |
FTA Tester, I opened the file using OSEDIT and it successfully opened and I see all my favourites but when I download it on my receiver I don't see the channels at all. |
Post Number: 73 Registered: Mar-07
| Posted on Friday, January 04, 2008 - 11:45 pm: |
Signal is more 90%, port setting is set to COM1 and baud rate to 115200. After doing blind scan I get all the channels. |
Post Number: 1348 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:47 pm: |
After doing blind scan I get all the channels. ? |
Post Number: 74 Registered: Mar-07
| Posted on Friday, January 04, 2008 - 11:54 pm: |
Yes I get all the channels and then i have to sort them again.I wanted to avoid to do the blind scan by creating the SAT file and Channel file but that didn;t work as when I loaded Channel file though it was successfull I didn;t get my channels or favourites. |
I WILL FIND...
Post Number: 3207 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:04 am: |
just do a factory reset, and put the satfile and channel list in from the computer....easy |
Post Number: 75 Registered: Mar-07
| Posted on Saturday, January 05, 2008 - 12:08 am: |
Did that too and same result. I guess may be the channel file and uploaded from STB to PC was not done right. Hence I will do it again using OSEDIT. Going by the rate of ECM I am sure it will come handy. Thanks for the help FTA Tester and Sada Bhai. |
I WILL FIND...
Post Number: 3210 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:11 am: |
i dont get it you used the loader program to install the channel list into the receiver? |
Post Number: 77 Registered: Mar-07
| Posted on Saturday, January 05, 2008 - 12:14 am: |
Yes I used Loader 2, loaded the bin file and then loaded the channel file and hit PC -> STB. The download was successfull. When i turned on the reciever I saw that the new bin was there but I was not seeing any channels (and Favorites I created). |
I WILL FIND...
Post Number: 3213 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:16 am: |
ok for some reason the list did not "take" oh and you forgot the satfile! factory reset, new bin, satfile, channel list, make popcorn, watch tv |
Post Number: 79 Registered: Mar-07
| Posted on Saturday, January 05, 2008 - 12:17 am: |
Also when I edit the cha (Channel) file in OSEDIT I see all my favourites and the channels listed under the favourites. |
Post Number: 80 Registered: Mar-07
| Posted on Saturday, January 05, 2008 - 12:19 am: |
Do I upload the SAT file from STB -> PC in the same way I did for the channel file ? |
I WILL FIND...
Post Number: 3219 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:39 am: |
go get a fresh one from viewsatusa.com its on their support page |
Post Number: 81 Registered: Mar-07
| Posted on Saturday, January 05, 2008 - 12:49 am: |
Thanks got it from viewsatusa.com. Thanks for your help. |
I WILL FIND...
Post Number: 3228 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:59 am: |
cool no problem... |
