Thread: A Great Deal ! ? |
Silver Member Username: 1tina_chick
Post Number: 143 Registered: Mar-06
| Posted on Friday, January 04, 2008 - 11:19 pm: |
A HDMI HD Box for $199 Neusat 9000 HD -What about Support ? What does everyone think ? A GREAT BOX or What ? A USB programmable, Free To Air, Digital Satellite Receiver that can be accessible to over 120 satellites receiving over 6000 television and radion channels. A receiver that is fully MPEG 2 / DVB Compliant with Picture-In-Graphic functions, multi-Picture (4,9,10,13 or 16 pictures), and the most comprehensive multi-language support in the industry. Sti7710 200Mhz Processor chip SDRam 128mb memory 8mb Flash memory S/W upgrade and download through USB 2.0 USB Memory Stick Interface USB PVR Function HDMI YPbr Component S-Video & Composit video Smart Card reader DVB-S fully compliant On Screen Display with 256 color Blind Search(Power Scan) Powerful search CH.(Power Scan) Powerful search function :Automatic,Manual(PID) & TP search Multi-Satellite & TP Search Powerful EPG: 7days program guide SPDIF Digital Sound DiSEqC 1.0& 1.2 compatible and ULSALS supported 8 Favorite Channel Groups Multi language supported (OSD&Menu) Total 5,000 channels Multi Pictures Function(4~16pictures) True 16:9 widescreen AC-3 Digital Sound (VFD)Vacuum Fluorescent Display on the front panel 1 Year Warranty. |
Gold Member Username: Saqeeb9000
Post Number: 1337 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:21 pm: |
tina if its not working all the time then it's not worth to buy it .. buy nfusion up 90% of time |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 3196 Registered: Sep-06
I know nothing about them...tried to look at them found very little support.... I bought a nfusion good luck |
Post Number: 1340 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:22 pm: |
c0st $ 220 (spend $ 20 more )... its worth it.. |
Post Number: 144 Registered: Mar-06
| Posted on Friday, January 04, 2008 - 11:26 pm: |
Thanks Boys, Best bang for Buck in this price HD,What da ya think ? |
Post Number: 1343 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:31 pm: |
support with HD sonicview 8000 (hd)+ u have to pay extra to buy an adapter in order to watch dn hd (up 75% of time).. most of time they have bin's fist.. without hd .. nfusion best choice..(up all the time) |
Post Number: 145 Registered: Mar-06
| Posted on Friday, January 04, 2008 - 11:42 pm: |
I like the views*t Pro's price and features but I need HD in this price range, any ideas ? |
Post Number: 1349 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:51 pm: |
so is it support or price? |
Post Number: 146 Registered: Mar-06
| Posted on Saturday, January 05, 2008 - 12:19 am: |
Both - Bang for Buck (HD) I'm still shopping what a Girl does best ! |
I WILL FIND...
Post Number: 3225 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:54 am: |
I as well have a wonderfull HDTV . I spend a few DAYS looking at hd receivers way to high at the moment..and decided to wait. I got a NFUSION instead. I can get abc, cbs, anf fox here with my OTA antenna so its cool for now.. |
Post Number: 149 Registered: Mar-06
| Posted on Saturday, January 05, 2008 - 01:32 am: |
Thanks FTA I Know OTA Looks GREAT ! - In HD - AS you know, HD Boxes now around 2 Bills but which one ? |
I WILL FIND...
Post Number: 3234 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 01:36 am: |
a HD box with good support is not 200 more like $700$ I am gonna wait |
Post Number: 151 Registered: Mar-06
| Posted on Saturday, January 05, 2008 - 01:44 am: |
2 Much for me I like the ones i've seen for 2 bills |
I WILL FIND...
Post Number: 3238 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 01:45 am: |
what brands are you seeing for $200? Lets go read some reviews n them...see how good the support is |
Post Number: 152 Registered: Mar-06
| Posted on Saturday, January 05, 2008 - 01:50 am: |
Neusat and others |
I WILL FIND...
Post Number: 3241 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 01:56 am: |
Neusat is a great receiver I almost went that way myself but, never found the correct forum for support. It is complex and uses IKS like the nfusion has to connected to the nett at all times... |
Post Number: 153 Registered: Mar-06
| Posted on Saturday, January 05, 2008 - 02:08 am: |
I like the views*t Pro's price and features - USB, fast chip, RGB, Hard drive via USB , massive RAM and Great support - Right ? What % does it go down vs Up time |
I WILL FIND...
Post Number: 3247 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 02:18 am: |
same as all other regular FTA receivers last few weeks 50% it is not a HD receiver nfusion is 99% working and it also is a dvr if set up to be.. |
