Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > Problem wich Ariza 700
Author Thread: Problem wich Ariza 700
Username: Chichos26
Post Number: 49
i have no chanels in ariza 700 which the new bin
MINGO NEW ARIZA FIX 2/1/ 2008
Username: Chichos26
Post Number: 52
can you help me plz
Username: Saqeeb9000
Post Number: 1325
download the channel list again.. from your home site for ariza..
Username: Burnabyh
Toronto, On
Post Number: 24
i have the same problem. i downloaded aa-1 for Ariza 700 which turned into 700S. So i downloaded aa-2 which seemed to be right. however, i only got a blank screen - not able to get the MENU key worked at all. someone knows Ariza 700 please help !!!
Post Number: 1326
do a factory reset and reload the bin.. sometime's this solve's the problem.
Username: Chichos26
Post Number: 53
sada but yesterday he worked fine and today i can't see anything waiting for picture 3000%... auto rool don't work or what???
Username: Burnabyh
Toronto, On
Post Number: 25
sada, how to do factory reset?
Username: Waderya
if you have a 700 always download aa-1 if you have a 700s the bin is well marked for that reciever. make sure you use proper bin you will cook your reciever the aa-2 bin is for the 750.the current bin has some freezing issues after you load the right bin and scan for channels hit menu then parental control under old pin enter i 2004 got key emu turn autoroll on exit out of that then go to set default key hit ok do this 2 or 3 times exit out back to tv picture. turn to cnn and wait slow rolling but it will work it will say scrambled or bad channel just wait a second the picture will show up in a second. worked for me came right from the man himself. its better than no tv at all.
Username: Lemonman
Post Number: 10
i factory reset my ariza and loaded the new bin and tried scanning for channels but not get anything. plz help
Username: Pannu16
Post Number: 728
no autoroll working, manual keys work!!
Username: Lemonman
Post Number: 11
i dont have any channels and when i scan it doesnt find any. wtf do i do. i have nothing to watch on tv anymore
Username: Chichos26
Post Number: 54
ryan gould.... Thank u ..... I'm gonna try tomorrow
Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > Problem wich Ariza 700 [ « Previous ] [ Next » ]
