Thread: Please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Silver Member Username: Guanajuatos_best
Post Number: 127 Registered: Jul-07
| Posted on Friday, January 04, 2008 - 09:10 pm: |
i'm only geting 300 channels on my xtreme after blindscan. pointing at 110 and 119. please and thanks |
Gold Member Username: Saqeeb9000
Post Number: 1320 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 09:11 pm: |
try to do a factory bin and reload the bin .. |
Post Number: 128 Registered: Jul-07
| Posted on Friday, January 04, 2008 - 09:32 pm: |
do you think that 75% of signal strength and quality affects this? |
Silver Member Username: Lol
Post Number: 164 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 09:36 pm: |
never Blind scan thats for FTA channels only |
Post Number: 129 Registered: Jul-07
| Posted on Friday, January 04, 2008 - 09:37 pm: |
so then how do i get channels???? |
Post Number: 1323 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 09:39 pm: |
try to load a factory bin and reload the bin |
Post Number: 165 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 09:40 pm: |
autoscan one sat at a time in settings disable lnb to other sats and scan one at a time re-enable Lnb when complete |
Post Number: 166 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 09:41 pm: |
if you scan and end up with dupes disable auto scan and delete the dupes then re-enable autoscan |
Post Number: 167 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 09:42 pm: |
your making this chit 1000 times harder than it is |
Post Number: 130 Registered: Jul-07
| Posted on Friday, January 04, 2008 - 09:52 pm: |
Paul: will try. but i was not able to disable other lnb to other sats. you said that in settings but i was not able to find how. |
Post Number: 169 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 09:57 pm: |
the only paisa:: in settings antenna settings / LNB power just turn it off turn one LNB or sat on at a time autoscan then save then turn it off move to next sat turn LNB power on autoscan save then repeat no since scanning bev since it doesn't work with this bin |
Post Number: 170 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 09:59 pm: |
after done scanning make sure you turn Lnb power back on of course  |
Post Number: 131 Registered: Jul-07
| Posted on Friday, January 04, 2008 - 10:03 pm: |
all right thanks. it had been a while since i did not scanned channels and it seems that i'm forgetting things. |
Post Number: 132 Registered: Jul-07
| Posted on Friday, January 04, 2008 - 10:08 pm: |
one last thing to erase the duplicates can i use channel master and just click erase duplicates? thank you very much |
Silver Member Username: Scabz
Knoxville,
Tn
Us
Post Number: 250 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 10:10 pm: |
I always use autoscan and after that I rescan some tp's. |
Silver Member Username: Psychmonster
Rhodium Member Aint nuthin ...
Post Number: 456 Registered: Jul-06
| Posted on Friday, January 04, 2008 - 10:12 pm: |
thats 300 channels more than u got 2 days ago...chill out pleasssses!!!! |
Post Number: 172 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 10:13 pm: |
channel master is for morons turn off autoscan delete your dupes save then re-enable autoscan |
Post Number: 133 Registered: Jul-07
| Posted on Friday, January 04, 2008 - 10:14 pm: |
it sure is more than before. thanks |
Post Number: 173 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 10:19 pm: |
if you have massive dupes do a factory default then install latest bin reset your settings (remeber the settings // take digital photo of settings screen if you need too // ) and do your scans |
New member Username: Madflea168
Post Number: 8 Registered: Jan-08
| Posted on Friday, January 04, 2008 - 11:02 pm: |
in the menu where antenna setup, when you try to do the 110 or 119, make sure the upper corner do showed the SAT ID you receive, otherwise you will not get the right channels. |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 3192 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 11:10 pm: |
stop stop stop I made a guide for this!! located http://forum.ecoustics.com/bbs/messages/2/428318.html next time save yourself all this time and fallow that. now what is your lnb? is it a dish pro? the way you are decribing the trouble is what a dish pro will do with the wrong settings or a switch added to it please list your set up |
Post Number: 134 Registered: Jul-07
| Posted on Saturday, January 05, 2008 - 12:14 am: |
yup. using Dish Network Dish Pro Twin LNB |
I WILL FIND...
Post Number: 3214 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:18 am: |
ok do you have a disqc switch on it too? we are getting very close to having your receiver fixed |
Post Number: 135 Registered: Jul-07
| Posted on Saturday, January 05, 2008 - 12:22 am: |
nope. only the one with the lnb's |
I WILL FIND...
Post Number: 3218 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:37 am: |
you mean the one inside the lnb? or is their a switch mounted near the lnb |
Post Number: 136 Registered: Jul-07
| Posted on Saturday, January 05, 2008 - 12:39 am: |
the one inside |
I WILL FIND...
Post Number: 3221 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:42 am: |
ok cool and its just one dish 500 right? how do you have the antenna settings? |
Silver Member Username: Fortec01
Post Number: 124 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:46 am: |
does any1 know if there is a bin out there for fortec ultra |
I WILL FIND...
Post Number: 3224 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:48 am: |
cannon, I answered you in another thread all I am willing to tell a user that hijacks a thread. thanks |
Post Number: 137 Registered: Jul-07
| Posted on Saturday, January 05, 2008 - 12:51 am: |
FOR 119 LNB POWER= OFF LNB TYPE UNIVERSAL LNB HIGH=11250 LNB LOW=11250 TP. FREQ.= 1224 DISEQC 1.0= PORT1 (PORT2 FOR 110) MOTOR=OFF LEGACY SW=NONE all settings are the same for both satellites. only the port for diseq change. an how about we continue this tomorrow. have to wake early tomorrow and i really need some sleep. thanks |
I WILL FIND...
Post Number: 3226 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:57 am: |
ok cool I was gonna tell you that is correct but i have one here that likes the tone burst better so play with the disqc settings....try 3 and 4 then the tone burst....something will work let me know I will be in and out |
