Thread: Viewsat extreme[autoroll] |
Bronze Member Username: Mdl97
Post Number: 65 Registered: Jan-06
| Posted on Friday, January 04, 2008 - 08:23 pm: |
help downloaded new bin to viewsat extreme and its on autoroll for the longest time.what can i do.. |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 3179 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 08:26 pm: |
http://forum.ecoustics.com/bbs/messages/2/428318.html I made that guide to help with that problem |
Post Number: 66 Registered: Jan-06
| Posted on Friday, January 04, 2008 - 10:34 pm: |
thanks........ |
New member Username: Madflea168
Post Number: 7 Registered: Jan-08
| Posted on Friday, January 04, 2008 - 10:55 pm: |
tried set factory default on one of my xtreme which erased everything, need to re-scan all the SATs. But let the back main switch off a bit longer on the second unit, it came alive w/o any problem. if all the infos are there, setting the factory default will be my last option. |
I WILL FIND...
Post Number: 3189 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 11:03 pm: |
that is why you are alot better off to just put the satfile and channel list back on....takes another 2 min and well worth it. |
Post Number: 67 Registered: Jan-06
| Posted on Friday, January 04, 2008 - 11:54 pm: |
well it autorolled for about 5 minutes and then it came on.i guess all is well..........thanks everybody |
I WILL FIND...
Post Number: 3209 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 12:07 am: |
enjoy |
