Thread: Viewsat not scanning all the channels on 61.5 |
Bronze Member Username: Leo_here
Post Number: 26 Registered: May-06
| Posted on Friday, January 04, 2008 - 07:34 pm: |
Hi guys..I am having problem scanning channels 584 (Sahara Samay), 585 (Aaj Tak), and 586(Headlines Today) on 61.5 with my Viewsat Platinum. Can anybody help me out? |
New member Username: Madflea168
Post Number: 6 Registered: Jan-08
| Posted on Friday, January 04, 2008 - 10:50 pm: |
make sure your antenna is setup to the correct port in the menu and have the signal/quality and save it before you exit and scan. |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 3186 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 10:54 pm: |
Did you install a fresh satfile when you updated? we have been seeing here the viewsat losing data during the update process...
Silver Member Username: Scabz
Knoxville,
Tn
Us
Post Number: 254 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:35 pm: |
Tester I never install factory bin before new bin install and my ultra works fine. Now when I do install factory first and then the new bin I loose all my channles. So, rather than loosing all my channles i just install new bin . It works for me. |
I WILL FIND...
Post Number: 3201 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 11:45 pm: |
scabz please do not try to condirdict my post without reading it first! no were in any of my post or guide do I say install a factory bin....i advise to install a fresh SATFILE and you channel list! we have threads all over the place with users that did not do as my guide and are having trouble... |
Bronze Member Username: Xdetoursx
Post Number: 12 Registered: Dec-07
| Posted on Friday, January 04, 2008 - 11:49 pm: |
The way I fixed mine was by throwing it in the trashcan. Viewsat blows nut. |
I WILL FIND...
Post Number: 3245 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 02:02 am: |
viewsats are great you just have to upload correctly and they work great! |
Post Number: 27 Registered: May-06
| Posted on Saturday, January 05, 2008 - 02:42 am: |
I am getting all the other channels available on 61.5..Just having problem in getting the three I mentioned (584,585 and 586) Mad I learned alot from this site about ports and settings and thanks for your input but the only issue I am having is with these 3 channels. Do I have to scan a specific TP and how? |
New member Username: Zigziga
Post Number: 1 Registered: Jan-08
| Posted on Saturday, January 05, 2008 - 02:47 am: |
Leo, did do a hard boot (from the back botton) after downloaded the new bin. or maybe need to scan the 61.5 again. |
Post Number: 28 Registered: May-06
| Posted on Saturday, January 05, 2008 - 03:09 am: |
I have tried everything Installing factory bin then loading the latest bin Installing satinfo file again Hard booting again and again befre scanning. I scanned it like 100 times and got all the other channels but still no luck. Like I said the issue is with only 3 channels.It's not like the receiver have some problem as I used to get these channels before with the same receiver I have now.Its just that I didnt use it for a long time because I was using Captive Works. |
I WILL FIND...
Post Number: 3249 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 03:12 am: |
sorry your having so much trouble give me again the 3 missing channels I will go see whats up |
Post Number: 29 Registered: May-06
| Posted on Saturday, January 05, 2008 - 03:25 am: |
584 (Sahara Samay), 585 (Aaj Tak), 586(Headlines Today) |
I WILL FIND...
Post Number: 3253 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 03:35 am: |
584 Sahara--is on 148 transponder 12574 585 Aaj----is on 148 transponder 12574 586 headlines---is on 148 transponder 12574 here on my receiver and all working 100% |
I WILL FIND...
Post Number: 3254 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 03:36 am: |
I cant get 61.5 a house blocks anything east of 82 for me so I dont know they may be their as well |
I WILL FIND...
Post Number: 3255 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 03:40 am: |
According to http://ekb.dbstalk.com/61-5list.htm the 3 channels are their |
I WILL FIND...
Post Number: 3256 Registered: Sep-06
| Posted on Saturday, January 05, 2008 - 04:06 am: |
Ok found them useing my buddy's dish on 61.5 584---transponder 12384 585--transponder 12384 586--transponder 12384 all working 100% |
Bronze Member Username: Ehsankhan777
Post Number: 32 Registered: Jun-06
| Posted on Saturday, January 05, 2008 - 10:12 am: |
I had the same problem what i did was checked my lnb settings i had it on single then changed it to dp and scanned it again it picked up everything |
