Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > Scrambled or bad channel
Author Thread: Scrambled or bad channel
Username: Amira
Post Number: 14
Hi, I have Pansat 2700 and 2800 both of 'em with newest files, but all Im gettin' is "scrambled or bad channel" smetimes got "No signal". Since I've input new files also have problem with low signal quality. So I have to play with antena settings to get signal (which I never had problem in the past) Once I got signals all I'm getting is those messages. Help, anyone?
Username: Nydas
Post Number: 6803
1. Recheck you /TV setup for date/time
2. Turn autoroll and closed captions off
3. Set up favourties.
4. Use EPG button within favourites to change channels.
Username: Amira
Post Number: 15
Thanks Nalin, I'll try.
Username: Koko_wawa
Post Number: 194
you also using your remote hit 8282, then default key and continue according to Nalin instructions, it almost stops the freezing and scrambling
Username: Amira
Post Number: 18
Nope, it's not working only some channels starting with 19000+(cnn, hnn..) and 8000+
Username: Kirankumar
Kenya
Post Number: 623
Amir,
when you get scramble channel,wait for 20 seconds and see if comes up
Username: Ke5aqn
Post Number: 3129
Amir,
What is your lnb? Is it a DP or Dish pro...on a dish500 antenna ? How do you have these 2 receivers connected?
Username: Nydas
Post Number: 6832
You will have to restart with
1. Load appropriate BIN - jvvh_235 or CS_235t_lightning
2. Do "Default settings"
3. Recheck your TV setup for date/time
4. Turn autoroll on and closed captions off
5. Do Power Scan. DO NOT USE CHANNEL MASTER FOR CHANNELS.
6. Turn autoroll off.
7. Set up favourties.
8. Use EPG button within favourites to change channels.
Username: Psychmonster
Rhodium Member
Aint nuthin ...
Post Number: 445
try the JVVH bin...seems to eliminate some of CS_235 problems for some people
Username: Max_payne
hi i need new bin file for pansat 2700a please.
thx
Username: Ke5aqn
Post Number: 3136
their are no files here.
http://future-fta.info is the home forum for true pansats visit their and you will find the bin
Username: Amira
Post Number: 19
Ok guys, thanks for helping me . Here's the deal, pansat 2700 clone is connected to dishplus antena, and 2800A is connected to sepurate dish which was profesionally installed manny years ago(it's 18" dish I guess) so I have no idea which lnb's I'm using. In my settings I always input as "standard Lnb" never had a problem 'till now. I've tried everything i know and everything you guys said, nothing helps. I even reloaded bins few times.
Username: Ke5aqn
Post Number: 3239
you need to set the lnb for dish pro like you have fist off then rescan
I have a dish pro and once set it to standered and it missed a bunch of channels
Username: Charjam
Post Number: 285
i have a 2700a and i have the same problem
Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > Scrambled or bad channel [ « Previous ] [ Next » ]
