Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > C00lsat 7000 bin is out
Author Thread: C00lsat 7000 bin is out
Username: Skins971
Post Number: 12
CS 7000 bin is out and reported that it's working great. I'm about to try it now I will upload it in a min. Check yourself at www.f2atv.com
Username: Skins971
Post Number: 13
Yup works great, here's the download link:
http://www.fileden.com/files/2007/1/10/623508/cs7000_NORW_V131_20080104.zip
I had to upload it to my account, because the attachment was too big for here anyways, enjoy it while it's up!!
Username: Nydas
Post Number: 6763
C00LSAT BINs.
Nothing so far for C00LSAT 4000, 5000 and 6000
Only for 6100, 7000 and 7100
http://www.ftatalk.com/showthread.php?t=104600
cs7000_NORW_V131_20080104.zip (1.22 MB)
http://www.ftatalk.com/showthread.php?t=104602
cs7100_NORW_V131_20080104
http://www.ftatalk.com/showthread.php?t=104595
cs6100_NORW_V131_20080104
Username: Leafs
Post Number: 302
koolsat files posted at www.ftasolutions.blogspot,com
Username: Acuraex
Is everyone having same problem with CS 7000 running extremly slow please let me know how can I fix it thanks
Username: Kirankumar
Kenya
Post Number: 662
there is a 20 second delay when changing channel.apart from this everything is great
Username: Acuraex
Post Number: 7
Mine is taking more then 5 mins to come up channals any idea to fix it.
Kenya
Post Number: 664
acuraex,
This is what you need to do.
do a factory reset,when it asks for auto detect say NO.
now load factory bin 111 and again do factory reset and say NO to auto detect.
Now go ahead and load bin 131 and do a factory reset.
this time do YES for auto detect.
you should be set now but expect about 20 second delay on channel change.if channel don't change wait it will.
good luck
Username: Jppatelahd
Post Number: 49
hello african i waiting for u on another forum man from last one and half hour???
Kenya
Post Number: 666
Jignesh,
just go ahead and scan all channels,that will be the easiest solution for you
Username: Acuraex
Post Number: 8
Where can I get factory bin 111? what is factory reset? Thanks for your help if you can response one more time.
Kenya
Post Number: 673
you can get factory bin 111 at fatbins and also f2tv.
to do factory reset.
menu-system recovery-and follow instructions.
need any more help just post
Username: Fast107
Post Number: 25
where r the fck is the C-Sat 5000 bins
dang there is nothing to freik`n do in this place cuz its icey,cold,and every thing that needed to be fixed in my house is finished since we got this snow
Username: Bushdaman
Post Number: 109
there out just gotta know where to look!!!! 1.59 cs5000 and works great.
Username: Bushdaman
Post Number: 110
http://forum.ecoustics.com/bbs/messages/2/431162.html
Kenya
Post Number: 676
Shine man,
it's been out for a while .go to f2atv.the site is slow but keep trying.good luck
Home > Message Board > Home Video > Satellite TV > Archive through January 06, 2008 > C00lsat 7000 bin is out [ « Previous ] [ Next » ]
