New member Username: Doctor_mortis
Sydney,
NSW
Australia
Post Number: 2 Registered: Jan-08
| Posted on Thursday, January 03, 2008 - 11:53 pm: |
This ia a collection of unlocking instruction for LG DVDs that I found while looking for the appropriate one for my machine (LG DR275). BTW, nothing yet. If anyone could add some more you are very welcome. LG 2300 With "no disk" on tray, press sequentially in the remote control PAUSE,3,1,4,5,9: code -- will appear in the display. Enter the region or 0 for region free. ================================================= LG 3000 Press the Pause button on your remote control. Using your remote control enter the code 3, 1, 4, 1, 5 and 9, Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player Or Press the Setup button on your remote control then, Step, Next, Up and Down, select the region of your choice or Bypass for region free, save and then Exit the menu. ================================================= LG DVD-3200E Press the Pause button on your Remote Control Using your Remote Control enter the code 3, 1, 4, 1, 5 and 9 Press the 0 button on your Remote for Region free, 1 for Region 1 or 2 for Region 2 Press the Pause button on your remote control Power off your player and wait a few seconds Power on your player LG 3200E, LG 3520, LG 3350E, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4951, LG 4950S, LG 5083, LG 5822N, LG 593W, LG H13, ================================================= LG HDD/DVD recorder: LH-RH7500W (The LG Home Theater System, with 80G hard disk) 1. Go to setup. 2. Move to the LOCK icon. 3. press number 0 button on remote 7 times (0000000). This will toggle Region Free or Region Lock. ================================================= Power on the player with no disk in the drive 2. Press "PAUSE" on the remote 3. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display) 4. Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.) 5. Press "PAUSE" on the remote 6. Power the player off and then back on ================================================= LG LH-R5500W 1) Press 'setup' on remote control 2) Move down to the 'lock' picture 3) Press '0000000' 4) Select Ok when congratulation message appears ================================================= LG DS8400/8500 Turn on the player with no disk inside. - open the disk tray - push 3 times the 0 button on the remote - pushed the pause button on the player - push the 0 button on the remote - closed the dvd tray - turned the player off. ================================================= LG DVD step 1- POWER ON "NO DISC" appears on screen; step 2- press PAUSE, 3, 1, 4, 1, 5, 9; step 3- "CODE_ _" appears on screen; step 4- 0, PAUSE, then POWER OFF!!! LG LH-W750TA DVD Surround Sound player's Using the Remote: 1. Power On 2. Open Tray 3. Press 0000 4. TV will show blue screen with the following two lines: a. Region Edit: b. Region Code: 5. Enter 0 in Region Edit line 6. Press Enter 7. Press pause button 8. Power Off ================================================= LG RC6821W go to setup (press on the remote) move down to highlight the padlock logo (4th down) dont move across to sub menu just press the 0 seven times it will appear that you are now using region free. ================================================= Power On Door Tray Open Press Pause button type 0000000 Wait Power off ================================================= LG DV5502P Power On Wait No Disc Sign Press Pause button type 314159 enter 0 as a region Press Pause button to exit screen Power off |
