Thread: Nfusion owners.. |
Gold Member Username: Saqeeb9000
Post Number: 1283 Registered: Oct-07
| Posted on Thursday, January 03, 2008 - 06:47 pm: |
i know lots of people said that there nfusion heat up quickly. so most of us hang around ecoustics. .i just found this from nfusionfourm.com on top of reciever near the vent...u will see a plastic stick togeather with holes (its really stick togeather with the holes).. u can just rip the plastic or open the cover and remove it... it was the plastic that didn't let the heat escape from the vents... so do it right now before your nfusion burned up... |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 2999 Registered: Sep-06
| Posted on Thursday, January 03, 2008 - 06:49 pm: |
cool nice tip I was gonna look into the heat issue and add a fan if needed |
Bronze Member Username: Ncx
Post Number: 36 Registered: Dec-07
| Posted on Thursday, January 03, 2008 - 06:54 pm: |
Good post Sada. That plastic has caught a few people from what I've read. I had to look twice to realize it was even there when I first got my box. Even if the vent holes are cut through the plastic, the box will still run warm if you leave the platic on. |
Bronze Member Username: Merk
Post Number: 58 Registered: Dec-07
| Posted on Thursday, January 03, 2008 - 07:23 pm: |
ok nfusion owners do you have to install a driver for it to work mine came with cd that says driver on it did your's i looked through the owners manual but it does not say any thing about it what is your advice thank's |
Gold Member Username: Hardrockstriker
Post Number: 1016 Registered: Apr-06
| Posted on Thursday, January 03, 2008 - 07:29 pm: |
Good catch, Sada! Now I can stop using my nfusion as a hot plate. |
Post Number: 59 Registered: Dec-07
| Posted on Thursday, January 03, 2008 - 07:36 pm: |
it also came with a usb to null serial adapter and null cable. at the bottom on the cd it says driver on the bottom of it it says usb so maybe it the driver for the usb i was just a bit confused by it. |
Post Number: 1017 Registered: Apr-06
| Posted on Thursday, January 03, 2008 - 07:42 pm: |
mjhp, please start a new thread next for a new problem. Just good ole fashioned netiquette. You need to install bin v1.42 via serial the first time you use your nfusion in order to have IKS. You can get this bin at http://www.nfusionforum*com/forum/index.php (replace * with a dot) |
Silver Member Username: Extremex
Post Number: 120 Registered: Nov-07
| Posted on Thursday, January 03, 2008 - 07:50 pm: |
Sounds like whoever you bought it from packaged it with a usb - serial adapter. That is what the driver cd is for. |
Post Number: 1285 Registered: Oct-07
| Posted on Thursday, January 03, 2008 - 07:51 pm: |
mine never came with the cd...........may be cd was for laptop's etc.. |
Post Number: 60 Registered: Dec-07
| Posted on Thursday, January 03, 2008 - 07:56 pm: |
thanks sada and other's i would have left the plastic on also good post.  |
Silver Member Username: Vndpatel
Post Number: 431 Registered: Mar-06
| Posted on Thursday, January 03, 2008 - 08:06 pm: |
BEV was down today at 3 it was down for 20 min and its back up now |
Post Number: 1286 Registered: Oct-07
| Posted on Thursday, January 03, 2008 - 10:09 pm: |
yep |
Post Number: 1335 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:10 pm: |
I WILL FIND...
Post Number: 3193 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 11:12 pm: |
Cant wait for mine to get here! |
Post Number: 1336 Registered: Oct-07
| Posted on Friday, January 04, 2008 - 11:15 pm: |
u should had got it from some sat store instead of ordering it online.. in canada canadapost sucks.. |
I WILL FIND...
Post Number: 3195 Registered: Sep-06
| Posted on Friday, January 04, 2008 - 11:19 pm: |
I am not in canada lol I am in okla no store near me |
Silver Member Username: Silver1123
Mexico,
DF
Mexico
Post Number: 410 Registered: Jul-07
| Posted on Saturday, January 05, 2008 - 09:33 am: |
Tester, the wait is worth. When your nfusion arrives and you install it, you will be jumping happily as I am. |
