Home > Message Board > Home Video > Satellite TV > Archive through January 02, 2008 > Is dn up and running
Author Thread: Is dn up and running
Username: Bugsbunny_satellite
Post Number: 20
i would like to know if dn is working and if so can i use my bev dish
Username: Chessy
Post Number: 48
some channels on dish are up but not alot... you can yous your bev dish but must reaim it to one of dish net sat..... hope this helps
Username: Dude123
Post Number: 1708
only locals are working on DN, no ppv, no internationals, and no adult channels only few local channels are working. If you want you can just change the position of your current dish to DN direction and you will get some locals but I would say its not worth doing it right now. Wait for the fixes hopefully they will come out soon...
Username: Ke5aqn
Post Number: 2881
it also depends on your receiver some are working better than others
Post Number: 21
i have a pansat 3500sd
Username: Dimwitt
Post Number: 337
Yes , you can use your bev dish to get DN .
Use www.dishpointer.com
set it up for your dish location and aim as shown , and adjust elavation till you get good signal(quality) strength
Post Number: 22
thanks
Home > Message Board > Home Video > Satellite TV > Archive through January 02, 2008 > Is dn up and running [ « Previous ] [ Next » ]
