Thread: Use STB or HDTV to scale sd broadcasts? |
New member Username: Jcamp
Lancaster,
Ohio
Post Number: 7 Registered: Jan-05
| Posted on Wednesday, January 02, 2008 - 02:01 pm: |
I have direct TV hr21 box, Sony xbr4, use hdmi for connections. Do I set the STB to NATIVE and let the TV do all the scaling or do I select 480p,720p, and 1080I on the STB. Or what? |
Relevant Product Info
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 2013 Registered: Feb-04
| Posted on Wednesday, January 02, 2008 - 11:36 pm: |
If Native is the same thing as "pass through" I would be inclined to use that. I find it hard to believe that the deinterlacer/scaler would perform better in the HR21 than the video processer in the XBR4. I would also try comparing that setting with 1080i since that is closest to your display's native resolution. |
